I’m about to build an armoire-style entertainment center. I’d like to make a story stick so I can leave my tape measure in my pocket. Do any of you have suggestions for the material for the stick?
Scott,
I found some pre-primed pine that I cut in strips. The surface is easy to write on and legible..and it soft enough to get a nice sharp line. Is that the kind of thing you were looking for?
BG,
Yes, that's the kind of idea I'm looking for. Are you ever concerned with the stick shrinking and growing with changes in heat and humidity?
Scott
Scott,
You can buy primed composite wood and cut in strips also. But, no, I don't wory about shrinkage...the wood changing length wise is extremely small if at all...
For story sticks, I use quarter-inch plywood. For patterns (i.e., it's going to be used with router and a pattern bit, etc.), I use one-half or three-quarter inch plywood or MDF.
David
Look, I made a hat -- Where there never was a hat!
Scott,
My story pole layouts are on 1 x 1-inch rips, as long as the wall is wide or the ceiling is high. On horizontal poles, I layout base cabinet carcases on one facet, roll it 90-degrees to lay out base doors, roll it again for upper carcases, and again for upper doors. If the wall is wider than my sticks are long, I join two on the job-site, butting their ends against opposing walls and screwing them together in the middle (I just lap them). I do the same on vertical sticks, and the room generally needs only one depth stick, again using all four facets - two for base cabinets (carcase and their doors), and two for uppers.
For complicated corner's or multi-sided cabinetry and furniture(like islands), I layout horizontal lines on plywood.
Although I now design and layout on Cabnetware software, I still use story poles for cabinets and furniture I can't design with the software, or to check the software's solutions. The 1 x 1 poles are good, because they contain just one wall on one stick, and it's easy to align cabinets over one another. Also, I make them from scrap. Painting would be good, but I use poles and plywood many times, sanding away old lines to layout something new.
Boatbuilders layout all three dimensions, as well as diagonals, on a painted "loft" floor, which is often the floor above the building floor. Those "lines" can be pretty dizzying to look at.
Gary
Edited 12/9/2002 6:28:44 PM ET by Gary Weisenburger
1/2" x 3/4" clear pine parting stop is a cheap moulding available almost everywhere, and can start life as a story stick and evolve into shelf edging, paint, shim stock, paint sticks and kindling.
For kitchen cabinet layout I use 3 inch rips of 3/8 or 1/2 MDF siting uppers along top edge and corrosponding lowers along bottom edge.In 8 foot lengths it is easily portable to and from the job site.
