Strange snipe problem with Dewalt planer
A neighbor of mine has a ~12″ Dewalt planer that’s about three years old.
Apparently, he’s getting some intermittent snipe problems. The odd thing is the location of the snipe — it’s NOT at the beginning or end of the board, but just some random spot in between.
The problem is only intermittent — it only happens on some boards, not all of them.
Also, the boards are well supported, so that doesn’t seem to be the nature of the problem.
Has anyone come up against this before?
Thanks in advance for comments.
I would be willing to bet that sharp knives, cleaned feed rollers and a waxed bed will solve the problem. Guess is that the lumber is momentarily stalling, which is causing that strange snipe.
Bruce S.
Thanks for the help, Bruce. I think that the problem has to lie with the feed rollers, too. I'll find out whether my neighbor has tried cleaning the rollers and waxing the bed. I'll also have to ask him to find out whether a temporary stall in the feed rate is consistent with the snipe location.
Has the other side of the board been flat jointed prior to planing?
Hal
No, the boards hadn't been trued up first.
However, he said the boards showed no significant cupping, warp, etc.
The weird thing is that the problem really is intermittent. I'm starting to wonder if it's some sort of variable mechanical problem, like a chip or loose piece getting trapped under a drive belt, etc., and then working its way loose again. He says that there's a weird, mechanical noise whenever the anomalous snipe occurs.
"I'll find out whether my neighbor has tried cleaning the rollers and waxing the bed. I'll also have to ask him to find out whether a temporary stall in the feed rate is consistent with the snipe location." Don't forget the knives!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
He's already inspected and replaced the knives to troubleshoot that possibility.
I asked him about the feed rate, and he said its been very consistent, i.e., no slippage related to the feed rollers.
This is an interesting little puzzle!
Hope you'll let us know when you guys figure it out. The wayward chip or other debris sounds like a possibility. forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
We repeatedly see waxing planer tables curing all sorts of problems. If nothing else, it should be a starting point in the diagnosis of the problem. It's easy and if not the actual problem will help narrow the field a bit.
Tom Hintz
Because there is always more to learn!
My guess would be that the board is not completly flat. That there is a cup in the board therefore the rollers will engage on the outside of the board and cut but not in the middle, until you've planed through the sllight cup that is in the board. This is just a guess though.
Kaleo
http://www.kalafinefurniture.blogspot.com
Dear Ragnar,
I have stalled a few pieces in my Makita planer and have never had any "snipe". I have had the feed rollers "polish" a section, but no deep cuts. If the cutterhead is not moving, and the rollers are maintaining pressure, then I'm not sure how a "snipe" in the middle of a board would be possible. I agree on a mechanical anomaly or chip or something, but I don't think that wax job will do it. It won't hurt, by any means, but the problem sounds mechanical.
Best,
John
Thanks to all for the ideas on this problem so far. I'll be sure to post here with the results once the problem is figured out.
Ragnar
Ragnar,
I have a Dewalt planer too but never had such a problem. As we all know what causes snipe is when the board is under only one feed roller and the board tilts upwards into the blades. This can happen at entry or exit. Based on this theory there is no way the board is going up into the blades in the middle. The only possibility that I can think of is that the blade carriage itself or some loose blade is falling down onto the board and causing this snipe to happen. And that is the cause of the noise as you mentioned.
I have had feed stalls and as one of the posters said it just causes a little polishing but never a snipe.
hope it helps. good luck
ds
Hmmm. Strange problem, but the first place I'd look (assuming you've eliminated the obvious such as buildup of stuff on the underside of the board as it's going through) is the bearings. My DW planer (old style) has some pretty crummy bearings that ended up seriously elongated after only moderate use -- so much so that the roller drive belt began skipping teeth. (I don't know if they upgraded the bearings on the newer models.) You may be experiencing a similar problem where one or both rollers are losing downward pressure as the roller moves around in the bearing. They are a bit of a pain to replace, but not awful and, since they are cheap (crummy), they are cheap ($$)!
Mike Hennessy
Pittsburgh, PA
For anyone who might be interested, my neighbor threw in the towel and took the planer into the service center. It seems they replaced a drive sprocket with several broken teeth, and also replaced a feed roller.
Unfortunately, my neighbor didn't ask a lot of questions at the service center and is thus unable to provide details regarding what was actually wrong -- I just thought I'd post what little I know.
Thanks again for everyone's input on this!
Ragnar
Did that fix the problem?
Rich
