I have been using a Spar Varnish mix, based on recommendations from several Fine Woodworking authors, including G. Hack. L. Schleining and R. Johnson. These recipes vary from author to author, but essentially say that a little tweaking is fine. This makes sense to me as well, the Varnish adds the alkylds, the oil makes the spar varnish an even longer oil, and the dryers do their work.
Problem:, No matter what recipe I use, I have streaks in the finish when viewed with raking light. The streaks are with the grain, so I am doing something wrong with application or wiping off, right? They do not have any surface texture to them, they look “dry”.
Here’s what I did: I sanded the top prior to adding finish with 600 grit, and it looked great. Denubbed and got all the dust off. I have two coats on now, and can see the streaks. Between coats, I have sanded the finish with 400 grit.
Coats consist of 1/3 McClosky’s Spar Varnish (Red Can), 1/3 Danish Oil, and 1/3 Turpentine, and sometimes Japan Dryer.
Also, any advice on streak removal would be helpful.
Ken
Spar varnish remains spar varnish--a varnish's long or short oil status is fixed in the manufacturing process; adding oil subsequently just creates a mixture of the two substances. Danish oil is already a mix of a different varnish, oil , and (perhaps mostly) thinner, and turpentine is just a different thinner. The Japan drier just confuses the chemistry, possibly impacting certain elements in your mixture more than others.
Sounds like you aren't wiping off the material as you should. Oil varnish mixes, which is just what this is, are too soft to want to leave any film on the surface. (You have just another "Danish oil" with two sources of varnish.) Apply wet, let penetrate for a few minutes only (especially if you have added Japan drier) and then WIPE IT OFF. ALL OFF. This sort of finish just isn't supposed to leave finish to be sanded between coats. You should be just trying to get the wood evenly penetrated so that it has an even, wetted out, look, with no apparent finish. If you still have streaks after wiping it all off, then you had streaks in the bare wood, though your overkill sanding to 600 grit ought to have revealed any remaining scratches.
If you want any sort of film use varnish only, and preferably NOT spar varnish which is also pretty soft and less water resistant than interior varnishes. You can thin any oil based varnish to make a wiping varnish, which you can apply in very thin damp coats, to build any film thickness you want. This isn't a wipe on, wipe off process but one of spreading the varnish very thinnly and evenly. You can apply up to three coats in a day, if you apply them just after the preceeding coat has dried enough not to be tacky. (Sanding not needed (or really possible) between these coats.) Then the set of coats should be allowed to cure overnight, and then scuff sanded before adding additional coats. Those bunched sets of coats crosslink enough that will be able to rub out the finish without witness lines between those coats.
Steve ----
What's the function of Japan Drier? As the name implies, can it be added to finishes (either varnish, or vanish mixes) to speed drying?
Japan Drier
Japan drier consists of metal salts, usually cobalt, in an appropriate solvent. It acts as a catalyst to speed up the curing process, which I understand is oxygen dependent polymerization. It will speed up the rate of cure, but is not necessary as varnishes, boiled linseed oil, alkyd paints etc., already contain some drier. The effect can be seen by comparing the drying times of 'boiled' vs raw linseed oil and pure vs 'polymerized' tung oil.
Japan drier adds an additional dose of the metallic salts that can accelerate the curing process. But, since you don't generally know which particular driers the manufacturer of thede BLO or the varnish has used, or for that matter you seldom know which drier or driers the Japan drier contains, you run the risk of having too much drier, especially with some versions of the "hot" finish. Too much drier can result in brittleness and reduced adhesion. At the best you would be increasing the speed of the cure a little, but without really knowing the chemistry you can't really predict that speed increase accurately and shouldn't add additional coats, etc much ahead of the normal schedule anyway. Just doesn't make much sense for a routine addition to a product mix.
Alternatively you might try a mix of 1/3 varnish (spar or non-spar), 1/3 boiled linseed oil and 1/3 mineral spirits. A local woodworking store owner said that is the general content of danish oils. His additional recommendation was to use a bit less boiled linseed oil if using spar varnish. Wipe on, then agressively wipe off until a clean towel doesn't pick up any more.
Aggressive Sanding
The varnish mix to which you refer is intended as a penetrating finish. By sanding to 600 grit, you may have burnished the surface to the point where the pores are sealed and the finish cannot penetrate. Before your next application, rough up the surface by sanding 120-150 for hardwood and 180 for softwood.
Don
This is simple, use a 3M pad equal to 600 grit and go with the grain like the 600 sandpaper, but after the sandpaper. The sandpaper leaves the streaks because you are hitting the high points only. The 3M pad gets into the grain as well and finishes the process equally. I apply the finish then wet sand it with a 3M 600 (equal) pad, lightly with the grain, let sit until ready to wipe, and wipe dry. If I do this for each coat, the newly applied finish slightly softens the previous coat and a light rub with the 3M pad removes any errors as well as etches the previous coat improving adhesion. I only use dry sanding for brushed or sprayed coats to flatten and I use the 3M pad, dry, to even it all out, but the coat must be hard enough to to avoid tearing the finish. You can even go to a white 3M pad, the super fine, as this will remove even less finish on the wiping type finish, allowing you to build the finish faster.
This is very useful information for me. Thank you very much!
Milbemax Supplier
Milbemycin oxime is vigorous against a lewd spectrum of nematodes, although it is less potent against heartworms than ivermectin. Its miticide spectrum includes Sarcoptes and Demodex. The USA FDA mandate on milbemycin oxime as formulated alone does not call for insecticidal activity.[1]
The substance is instances combined with other parasiticides to achieve a broader spectrum of action. Such products include:
Milbemax (with praziquantel)
Sentinel Flavor Tabs (with lufenuron)
Trifexis (with spinosad)
Recently the pharmaceutical has been acclimated to in maritime reef aquaria to hold sway over parasitic harptacoid copepod (Tegastidae) infestations on captive devastating coral colonies. It is an effective detailed tank treatment to save these parasites because it is not toxic to corals in the dosage required to despatch the parasites. Shrimps, crabs and other crustaceans should be removed former to treatment, as they determination be killed through the treatment.
From [url=http://www.tcsindustry.com]TCS INDUSTRY LTD[/url]
Moxidectin Supplier
Moxidectin (Milbemycin B[1]) kills parasites, so is used for the restraining and manage of heartworm and intestinal worms, and can be originate in treatments prescribed to go to animals such as dogs, cats, horses, livestock and sheep. Application methods for moxidectin diversify by treatment, and include voiced, current, and injectable solutions. Cydectin Flow On is a barter cite after a formulation in compensation urgency on beef and red deer.
Moxidectin is a semisynthetic derivative of nemadectin [2] which is produced past fermentation before Streptomyces cyano-griseus. This Streptomyces species was discovered in a excrement sampler from Australia in the late 1980s unruffled alongside an agronomist working in the direction of the American Cyanamid company.
Moxidectin treats and controls some of the most mean internal and outward parasites by selectively binding to parasites’ glutamate-gated chloride ion channels. These channels are mandatory to the r搇e of invertebrate nerve and muscle cells; when moxidectin binds to the channels, it disrupts neurotransmission, resulting in paralysis and cessation of the parasite.
Studies of moxidectin steer the side effects restyle at near fleshly and may be fake beside the yield’s formulation, pertinence method and dosage. The products are usually recommended by a veterinarian to insure factual avail oneself of and application. Herding dogs may be avermectin-sensitive, but avermectin-sensitive dogs can turn a blind eye to standard doses after heartworm prevention. Moxidectin is seemingly safe in regard to collie breeds. As a heartworm preventative, moxidectin can be injected in a minute every six months covered by the brand name tag Proheart6, or every 12 months under the label eminence Proheart SR 12.
Moxidectin is the referred to of a trial to assess its suitability, as an alternate to ivermectin, to remedying onchocerciasis in humans.[3]
From [url=http://www.fmyykj.com]suzhou pharmaceutical technology co.,ltd.[/url]
Download over 16,000 WOODWORKING PLANS at here woodworkingplanspro.weebly.com Woodworking guide offers anyone of any skill level the ability to build amazing projects. The guide is extra helpful because it offers more detailed explanations, videos and blueprints then your typical woodworker magazine .
Hope it will help you next time !
This is very interesting information for me. Thank you very much for your attention.
A very good post. Thanks to the author.
