I’ve finished constructing the frame for Mike Pekovich’s low dresser shown in FWW 248 and I am now ready to attach the top. The frame is built like a tank and the top is going
to be screwed to a frame of kickers beneath. Here’s my concern: Inevitably someone is going to try to lift the dresser by holding on to the overhanging top. While the top is well-attached to the kickers, those in turn are attached to horizontal rails which fit in bridle joints at the top of the legs. Essentially all of the weight of the dresser will ultimately bear on those 4 bridle joints if lifted via the top. This gives me pause! I’m considering some metal brackets to join the kickers to other parts of the lower frame. Any advice?
Bridle joints are phenomenally strong. They will not fail in such circumstances as long as reasonably constructed. That having been said, the joints in question are not deep at 1/2 inch x 3/4inch so I can see why you have concerns.
Even so, I would not be adding additional metal. If I did, it would be a 100mm x No8 screw right down through the joint from the top.
Since the outer kickers and the upper rails of the sides appear to run in the same grain direction, I would consider connecting them together to help support the top since as you say it will be attached to the kickers. Possibly by gluing the kicker to the rail at least partially and/or add a couple pocket hole screws, recessed screws or edge dowels to connect the two members together.
While I haven't looked up the piece, I'm not a fan of using metal in fine wood furniture. If the bridle joints are well cut and glued I think they will be fine. How often do you see the piece being moved? If you are concerned about it, is there a way to pin the bridle joint to reinforce it?
Not answering your question, but I have often thought that consideration of how to facilitate moving furniture around should be part of the design.
But I for one don't consider it a sin to use metal parts to reinforce wood.
Checked out the plans and I would go with installing metal “L” brackets between the end kickers and the side panels. They will be invisible and give peace of mind. Given the narrow stock of the top frame bridle joint, I would hesitate to drill and screw.
Thanks all. I've considered both the L-bracket scheme and the vertical screw. I like the L-bracket idea, but it may be a bit more work (mortises in the kickers) to avoid conflicts with the top drawers. I think the long screw can be
done safely with the right hole and countersink, but as Elmaduro points out, those bridles are fairly narrow.
I'd also prefer the L-bracket idea! Even tho it's a bit more work, I think it's worth it! are you in a rush with finishing?
No rush, just trying to come up with a good plan. I'll probably go with the
L-brackets. Thanks!
