Dear FW:
I’m the caretaker of a 28-640 Delta 20″ band saw, circa mid-90s, made in Taiwan. I’d like to remove the lower wheel to replace the drive belt, which is showing signs of wearing out. The threaded bolt came out easily but the wheel itself refuses to budge. Do I need to use a gear puller? Are there other steps I should take first? This the model with the foot brake, if that helps.
Thank you,
Steve B.
Gear puller.
