T-tracks often not needed
![](https://secure.gravatar.com/avatar/5dfd4289ab27927c839463cf6145a1c0?s=52&d=https%3A%2F%2Fimages.finewoodworking.com%2Fapp%2Favatars%2F200x200%2Fh.png&r=g)
I sense that T-tracks are used indiscriminately. T-tracks are needed generally only where continuous attachment is needed, such as stops.
For clamping, a cheaper and strong mechanism is usually available. Here, the positioning of a few T-nuts (planned in advance) or threaded insert (more afterthoughts) is better and cheaper. Many hold-down type clamps are available.
Best are hold downs clamps that are not permanently attached; only 2-4 such clamps per woodworker will suffice for all jigs where they can be used. Less economical is the use of toggle-type clamp attached for that jig alone.
Just some thoughts to save money
picked up 3 good toggle clamps for next to nothing in MLCS's bargain bin. All sites have discontinued items or sale items or bargain bins.
Personally, I like t-tracks and wooden screw clamps.
Mikaol
Often the only uniquely useful toggle clamps are the horizontal action type.
Otherwise, toggle clamps are often not necessary, though sometimes they are
With T-nuts or threaded inserts, jigs are flatter and easier to store.
With Jorsenson type holddown, only a few 9/16 head hex bolts are needed and attached only in operation. Only 2-4 are needed
There is also the longer reaching drill-press holddowns. Mine takes 12mm 1.75 threads. Only two are needed.
