Hi All
First post here.
I moved my delta contractor saw a couple of days ago and for some reason the saw has completely gone out of alignment. So far I’ve adjusted both the front and rear trunnions as far as I can but the saw is still out of alignment by about 3/32. Any help would be greatly appreciated.
Jim
If you moved the saw from one place to another, not just across the shop, and the motor was left on it, you might look for something bent (or broke) at or near the trunions and the bars that connect them. The weight of the motor bouncing around, even for a short while, on those mounts can do very bad things to a saw.
Tom Hintz
Because there is always more to learn!
