Table saw blade out of a parallel?
I have a 1 1/2 HP Craftsman hybrid table saw. The blade from front to back is 1/128 of an inch (I think that is about .005) out of parallel. Is this acceptable? I am a hobbyist and have been doing this on and off for 6-7 years. I make cabinets, keepsake boxes, things for the grandkids etc.
Frank
It's not the blade that is out of parallel, it is the table top (as measured by the miter bars) or the fence, as measured between the front and back of the fence.
Which kind of error is it in your case? This kind of error is more acceptable if it is the fence that is wider at the rear of the blade than the front. If the otherway around, you have a dangerous situation when ripping.
It is the table top that is off. I measured from the miter slots to the blade.
Frank
Here is the low tech, low cost way to align a tablesaw that I learned maybe forty years ago and use to teach to my students.
Make 3/4 x 3/4 x 12" hardwood stick. Drill a hole somewhat centered in one end and insert a brass #8 x 1" round head fine thread machine screw about half way. UNPLUG THE SAW. Raise the blade completely up. Clamp this board in your miter gauge (if you determine that there is some slop in your slot to miter gauge, use a playing card to take up the slop) so the screw head just about touches the blade at the front. Now rotate the blade by hand and determine which tooth is the closest. Adjust the screw in or out until it just touches this tooth. Mark this tooth. Rotate the blade so the tooth is now at the back of the table and move the miter gauge/stick assembly to the back and see if it touches the marked tooth to the same extent. If it doesn't, adjust the trunnion (if a contractor saw) or the tabletop (if a cabinet saw) until it does.
For a contractor saw, first use a small c-clamp on the rear trunnion and cradle to keep the assembly from moving. Then loosen the two rear trunnion bolts and one front trunnion bolt. Slightly loosen the other front trunnion bolt and use a stick to tap the trunnion until the blade and screw lightly touch. The blade does not move directly around the center so you will need to repeatedly go back to the front of the blade, readjust the screw, and then again measure the back. Be sure to check after tightening the trunnion as the trunnion frequently moves when being tightened.
For cabinet saws, loosen the bolts that hold the tabletop and tap one corner until things come into alignment.
The same adjustment gauge can be used to set the fence parallel to the miter slot. Slide the miter gauge to the front of the table and move the fence over to the screw head and insert a playing card between the screw head and the fence just so you can move the card as it touches both the fence and the screw head. Now move the miter gauge to the back of the table and see if you have the same feel when you insert the card. I like my fence absolutely parallel--if you want to have a slight opening to the fence, you can easily estimate the opening by adding a thickness of paper to the card.
I always show my students with a dial gauge that their adjustments are within .001 - .002.
You can also use the same gauge to measure blade runout by using a $5.00 feeler gauge.
Finally, after you are satisfied with the above adjustments, check the position of the splitter to make sure it is exactly in line with the blade.
Bottom line, there is no need to spend more than the $0.05 for the brass screw.
