table saw blade spins in two directions?
when i turn on my table saw it spins in one direction and when i turn it off than back on it spins in the opposite direction. what might cause that to happen? it is a direct drive motor not belt driven and is a 110 volt motor
I had a similar thing with a planer-thicknesser that began to go backwards now and then after switch-on. It turned out to be the capacitor used to provide the initial high power input on start-up of a machine to overcome it's inertia.
Capacitors degrade and apparently begin to misbehave. The planer-thicknesser item was rather bloated when extracted. A new one cured the problem (now at least 10 years ago, with no issues since).
If it is a simple matter of replacing a capacitor (or any other standard component of the motor circuitry) beware of the original manufacturer's item. They often charge a silly price for such things when a standard and identical component can be found, will cost a 1/3rd of the machine maker's price and may even work better.
With lataxe on this BUT - beware cheapo capacitors on ebay and similar. Capacitors need to be made properly and so most of us who play with such a lot generally buy a higher than required voltage capability. You need the same uF rating, but buy a 240V version rather than 110V. Higher voltage means a stronger, better built (also often larger) capacitor.
Thank you for your input. I will try that and see what happens
The capacitor can be an issue with an induction motor. But the motor in this case is direct drive, and all of the direct drive table saw motors I have seen use universal motors. And universal motors don't have capacitors.
