Table saw blade stuck when in a lowered position
I have a grizzly g0715p table saw. When the blade is at a fully lowered position, it seems to be stuck. As I raise the blade though, it starts to gain power and can easily cut anything I need it to. But only in a fully raised position. Any ideas on the problem and solution? Thanks
Belt loose? Tightens up when you lift it.
That was it
thanks
