It’s time to replace the blade on my Bosch 10″ portable table saw. Is there one blade that will give satisfactory results for all anticipated functions, or should I invest in both a rip blade and a crosscut blade?
You can get a combination blade but the number of teeth depends on what you normally cut. If you find that you rip a lot more than you crosscut, 24 TPI should be fine. If you do more crosscutting, 40-60 TPI may be better. Or, get one of each. I have used Oldham for quite a while and they do a decent job, although I needed to return the first three before the fourth was flat enough. The 40 TPI carbide blade I have is about $17 at Home Depot. I suspect the 24 TPI is about the same price. If you're doing a lot of trim work, I would get a 40 - 60 TPI. I'm not saying that the Oldham is the best, but it works and won't break the bank. When I need a really good finish, I have a Forrest WoodworkerII. Expensive, but better carbide and cuts like a hot knife through warm butter.
Rob
You can get a nice combo blade from Freud. I'm sure there are other manufacturers of them.
They work fairly well if you need to do both and only want to get one blade.
I prefer to have a rip and crosscut blade but when I'm trimming out houses I will often times use the combo.
I would avoid the cheap blades that you get a the big box stores, they IMO don't seam to be worth the money they cost.
Doug
A good combo blade like the Freud LU84 is good for most applications, but for heavy ripping, especially with a smaller saw, a dedicated 24T ripping blade is a good idea too.
Depends on what you cut. I've used a 40 tooth carbide blade for 95% plus of my work. If I'm ripping more than a piece or two of 2 X lumber, I'll switch to a 28 tooth blade. If I'm cross cutting, and need a fine finish, I use and 80 tooth blade. For hardwood plywoods I stick with the 80 toother (now that I have one), especially when crosscutting the face veneer. Mind you, I've only had this blade for six or eight months.
Rob.
As others have said, what you get can depend on the nature of your work. Having said that, I've used a Freud 50-tooth combo on tow different saws over a period of 6-7 years. It's a great blade for the money -- good price/value ration in my mind. I also have a Freud 'Glue-Line' Rip blade for major ripping operations as well as a Freud blade for gutting plywood and laminate. It's worth the time and effort to change the blade for some operations, but most of the time I use the combo with great results.
Bill Arnold - Custom Woodcrafting
Click Here if you're interested in a good,inexpensive website host.
No one has mentioned the kerf issue. Most portable saws come with a thin-kerf blade, and I suspect your Bosch is the same. If you change to a full kerf blade, you will notice a drop in performance.
I was very happy using a Freud TK906 (thin kerf combination) on my DeWalt 744.
Cheers,
Kent
I use mostly my Freud all-purpose blade, but have a Freud Diablo 24-T ripping blade for ripping stuff 1"+ thick just to take it easy on my saw. The Diablo rip blade is not expensive, works like a charm and is available at Home Depot and Lowe's.
Rob,
As you can see, there are several great blades out there. The most affodable for the average Joe, is Freud. These are great blades, made in Itally. I own Freud and CMT. It may be helpful for you to get seperate blades for ripping and cross-cutting.
Having a table saw with one blade in my humble opinion, is a mistake, unless you do limited, occasional woodworking. This may be your case; I don't know.
No matter what you buy, Take care of the blade and buy some blade cleaner to remove the pitch from the blade occasionally; even blades that still in good shape can perform poorly due to buildup of pitch.
Just inspect the blade from time to time for presence of pitch.
I recently bought a Ridgid sliding compound mitre saw (12") and discarded the chinese blade that came with it after about 50 crosscuts into 2x4's, as I was getting kickbacks and could see the carbide was dulling.
Don't be afraid to spend some more money and get a blade that is made in the USA; you can't go wrong with Forrest and the others, that are available here.
Stick with Freud or Forrest. Make tooth selection based on applications. If you can't afford more than a single blade right now, they both make excellent combo blades.
One caution - stay far away from the cheap blades. They are not worth the trouble.
thnx
scottd.
scottd
Damschroder Scott Furniture
scottd@mapubco.com
A craftsman needs three things: Accuracy, Technique, and Quality. Accuracy can be set; technique can be learned; but quality must be bought and built.
I've got a Systimatic combo blade that does well for 90% of what I do. I keep a rip blade around for heavy ripping or glue line work (can't recall the make) but the Systimatic does most of the work.
That said, I don't do much with plywood except to use it for cabinet backs.
