Hey everyone. I’m somewhat new around here but here it goes…
I’m looking for a few good suggestions regarding material for an extension table I’m building for my 10″ Delta Contractor’s Saw. It has a 52″ inch Unifence on a mobile base.
I recently built one but I’m not happy with the results. I used 3/4 particle board with a Poplar frame (running underneath on all four sides and with 3 cross supports stretching from each of the frame’s sides. This was laminated on top and sides. Unfortunately the extension table has sagged about an 1/8″ in the middle. I think it’s the length of the 52″ rip fence.
Is there a better material or design I should use?
Solan
Solan , One mistake is to laminate one side .You need to balance the laminate by laminating both sides .Apart from that I use 3/4 baltic birch for my extension and laminate both sides .Ensure that the support is adequate.I use 4" rips every 8-10 inches.My tables have stayed flat with years of commercial use
All the best, Jako
My dream setup for a table saw in my small shop is to have a sliding table saw with a second tablesaw in the extension wing. That way, I can leave a dado head in the second saw. It seems that I cut a lot of dadoes with my rip blade because I'm too lazy to switch from rip to dado and back. And it always seems that I need to rip something in the middle of my dado work!
and www.flairwoodwork.spaces.live.com)
Yup, laminate is perfect. You can use MDF since its dead flat and you definitely need to laminate both sides. Use contact cement and a roller and add some iron-on edge banding or to make it really nice, some hardwood edging. the top is then screwed to the support frame from the underside. I used to have a Craftsman contractor saw on a mobile base that I made extensions and outfeeds for using laminate and particle board (no MDF was locally available at the time). It stayed flat, but eventually began delaminating when I wiped it with mineral spirits to get oil and grease off of it.I now have a Sawstop cabinet saw that I made a mobile base for and added laminate side and folding outfeed tables to. I have a welder, so I welded up square tubing and angle iron for my supports, but it could have been made from hardwood.Edited 7/11/2009 12:23 pm ET by Michael666
Edited 7/11/2009 12:26 pm ET by Michael666
Unfortunately the extension table has sagged about an 1/8" in the middle.
Why worry about that? It just holds what is left over ...
Onto better things to worry about...
