Hoping to get started doing some woodworking. I’m looking for a good table saw and the General 50-175/50-185 seems to fit my budget. The 175 is a right cut and the 185 is a left cut. The left cut 185 seems to be available but the 175 are not. My question is what is difference between left and right cut? Is there an advantage or disadvantage to left cut verse right cut etc.? Also any feedback on this saw. Thanks.
Is that right and left CUT or TILT?
The web page shows 175 right cut and 185 as left cut. Under specs. it shows 175 arbor tilt range 0 to 45 degree to right. 185 arbor tilt range 0 to 45 to the left. Trying to figure exactly what it means and the advantages of left or right cut or tilt.
imho, it's a matter of personal preference and methods of work. I've used left and right tilt saws. The following link might help. http://benchmark.20m.com/articles/LeftVersusRightTilt/TablesawTilt.html
It also depends on the type of fence you plan to use. My saw is right tilt but the fence can be set up to work on either side of the blade so that there is no difference in functionality.
Left tilt seems to be more common and I definately think that it is safer when ripping at 45 degrees. I have a right tilt because the price was right. I like that I can still use the cursor on the fence when using a dado set. With a left tilt that isn't possible.
With a slight modification it's quite easy to calibrate the cursor on a left tilt saw to accomodate the "dado issue"!! By modifying the cursor mounting plate I can calibrate to either side of the dado or even the center and I have a preset stop to zero it back for the standard 1/8" blade so it's possible to expereince the saw to it's fullest. Never say something can't be done! Also one can also do the same thing with the http://www.digi-kit.com/ My version is a lot cheaper!
