I recently purchased a Delta Unisaw (CAT 36 R53L) 5HP 3 Phase table saw. I don’t have access to 3P power. Is there a bolt off – bolt on replacement motor from Grizzly or Leeson. I don’t mind giving up some HP power in going to 1P 230V but want the shaft, mounting brackets etc. to line up. Could use make, model number and recommended source for purchase. Thanks.
https://www.renovoparts.com/83-621-mtr-1ph-1-5hp-ts10-for-delta-power-tools/
This should fit your tablesaw.
Thank you.
