I have an old Craftsman 10″ TS. I am looking for some plans for a simple sled for crosscutting wide (approx. 18″) stock. I would like to know what overall length and width dimensions I should aim for (I have somewhat narrow space around my TS). What height should I make the fence? Do I need both front and back fences? I would like to have the capability to use the sled for making dado cuts also. Wanting to keep the sled blade slot as close as possible (almost zero clearance), would I need to use a completely separate sled for dado work?
Several publications offer plans for sleds. In fact, the latest issue of "Shop Notes" has a nifty sled featured that doubles as a miter sled. I've got one of each, but I'm looking at that one to save some room.
I would recommend a front and back fence, although I've seen some simple ones that just sit to the right or left of the blade. Those only need one fence.
Jackhall,
No, you really can't cut dado's on a crosscut sled..unless its a left tilt...and based on age alone your craftsman probably doesn't qualify.
A crosscut sled is no good unless its dead on accurate. So what ever you build make sure its adjustable and you can test frequently. Personally, I prefer one fense (in the front) 2" high which is attached to angle aluminum and the aluminum is attached to the sled (enlarged holes in aluminum and nuts and bolts). I use the Incra runner in the dado...adjustable for a nice snug fit. The overall dimensions are about 26x30. I like it to hang a bit off the table so I can attach a clamp if needed. I use the table saw fense and a carpenters square to check accuracy...
Thanks for the tips. Will use your advice on making the fence re-settable, however, I'm not familiar with Incra runners. Are wooden runners subject to wear or swelling and therfore not accurate? Also I don't know why I couldn't use a sled for cutting dados. What does saw tilt have to do with dados?
jackhall,
Yes, you can use wood runners...or plastic. I used the Incra (got it at woodcraft) because the oak did expand and contract and made the sled sloppy or sticky. The Incra is metal and adjustable with an allen wrench.
I assuming when you said you'd cut dado's that you would add dado blades to your arbor....and therefore cut into the sled?
Yes, I was referring to use of the sled to crosscut dados in cabinet sides, etc. The sled would need to have a suitable gap in the sled base to accomodate passage of the dado blades on the saw arbor.
jackhall,
Ok, were on the same wave length. Yup, you can use your sled for the dado cuts. I just use my fense and register off the table top...
Dadoes are fine on a sled, but you will lose your zero clearance aspect of the sled. Therefore, make a 1/4" plywood top for both sides of the sled, and use countersunk screws to fix it it several positions. Move it apart for dados; together for a standard blade. Or, make 2 sleds. I have seen it done both ways.
AlanAlan
http://www.alanturnerfurnituremaker.com
Highland Hardward has a very nice set of plans for building a sled. It includes a unique "handsaw like" handle that will prevent you (better said as encourage you) from accidentally putting your hand where the saw blade moves through.
Just built two of them. One for 24" wide stock and a smaller one for 15" wide stock. Wish I had taken pictures. I will endeavor to do so and post tomorrow.
Best,
Bob
I like the idea of using a top which I can adjust to keep tight clearances on different size dado stacks or a single blade. By the way what type of material and what thickness should I use for the base of the sled?
My preference is 3/4" mdf, finished with wiped on shellac. MDF is quite flat, which is what you need. That said, I do hate the stuff, and only use it for jigs, etc. I do have a piece 3 x 5 that I throw onto my workbench as a drafting table when I am doing large scale plans.
AlanAlan
My only complaint with MDF is its tendency to sag over long, unsupported lengths. In the case of the sled there should be no such problem. Desiring to retain as much blade height as possible, would 1/2" or 5/8" MDF be adequate?
I don't see why not.
AlanAlan
Thanks for the help.
I think you are right about MDF being a good flat product that should be just fine riding on the TS. My concern would be what to do with it when it is not in use. That would stink if it twisted or moved when being stored. Perhaps hanging it would do the trick. Then again, at the price, an MDF sled could almost be considered disposable.
I was my usual German self and way overbuilt the damn things. Mine are formica laminated 5/8" baltic birch with a 6/4" maple front fence and a 1.5" thick baltic birch (3 pieces of 1/2" laminated) back fence. I don't know why I cannot build a simple cheap jig, but it seems to be incompatible with my anal DNA.
Your version of the sled sounds great.
Am trying to attach pictures (files per below) but cannot seem to get it to work... Don't know what I am doing wrong.
I browsed, found the file, pressed Upload and then done and puff... nothing.
