Has anyone tried using a speed control on a contractor style table saw to reduce the speed while using a sanding disc?
Motor out side and in back of the cabinet (V belt driven)?
If the motor is out side of the saw cabinet you could change the pulley size . A smaller pulley on the motor will turn the sanding disc slower
AND
You will have more torque (can press the sander harder without slowing it down).
