Hi,
I’m new to the board and would like to get some feedback. Specifically, I am using a basic Skil model 3400 contractors table saw. It isn’t fancy but gets the job done if I am careful. (I had to laugh about those posting in the other thread about measuring the fence two or three times to make sure it was where it ought to be. Been there/done that!) It has table side extension add on and permanent legs attached. It is really a pretty good saw, but….well, basic. It was fine when I was finishing my basement, but furniture-making really buts up against its limitations.
Here’s the thing. I’d like to find a relatively inexpensive way to upgrade my fence and miter guage. First question, is it even worth it or should I just hang in there until I can move up to a mid-level machine? If so, any suggestions?
Thanks in advance for any help.
Woodchuck
Woodchuck- It's time to upgrade. There are a lot of great deals on Hybrid cabinet saws these days.
By the way there is a recall on the skill3400. Check It out on there website.
Thanks Walker1,
I wasn't aware of the recall. As much as I like lacerations and electrocution, I suppose I better get the recall upgrade kit! I spent 4-5 hours using that saw just yesterday.
If anyone is using the Skill Model 3400 (probably not many in this group;-)), you should take a look at the recall page...http://www.skil.com/Safety/3400/. You can order an upgrade kit online to get back in gear.
Woodchuck
Hi Woodchuck - I'm not familiar with the 3400 off the top of my head, but I'm not aware of any Skil table saws that have a fence that can be easily upgraded with any current aftermarket fences. If it's the saw I'm thinking of, you'll still have the issues of direct drive, small table surface and universal motor. My suggestion would be to see if you can sell it and step up to at least an entry level cast iron contractor saw.
Good luck!
Thanks Knot Scott and Walker1 for the replies.
Woodchuck
Woodchuck,
Most of us that have researched this issue determine a cabinet saw is the right way to go. I know, it sounds like overkill but when you look at all the factors (footprint, dust collection, vibration issues, resale value, maintenance, etc.)it really is a good decision....especially if you go with a used machine but that is not required.
