I currently use a sears table saw with a 1 hp motor; and, I have difficulty ripping anything over 1.5 inches thick and even that is slow. Will I be satified with a 1.5 horse saw for ripping 1.5 inch lumber at a 45 degree angle? Or will I have to step up to a 2 or 3 hp saw? Would working is just a hobby. I like to built furniture and need to rip at 45 degrees.
Have you tried a dedicated rip blade??? I've seen this complaint time and time again. Most folks use combo blades and they are a compromise on all accounts. A rip blade has less teeth and a flat top grind and rquires a lot less power than a combo blade. You should see a remarkable difference in performance. Cheaper than buying a new motor or saw upgrade.
Definitely go for the higher HP, especially if you plan to cut hardwood. Another idea, since you already have a tablesaw, is to get a bandsaw, and use it for the beveled rips. A bit slower, but will handle thicker lumber without requiring a lot of HP. And no danger of burning because the feed rate is too slow.
Bob
You can rip with a 1 1/2 HP if you go to a good quality 24 flat rip blade. A Thin-Kerf would benefit that. Avoid a blade in this case advertised as glue-line rip. It's a great blade for 1" and under, but the teeth are not set for quick removal of the waste generated on that size lumber. A 24 flat tooth is best, but will require a jointer or hand jointing to get the edge you need for glue up.
If you are doing a lot of ripping as I do, the 3 HP makes more sense if it is in the budget. I bumped my 1 1/2 HP up to a 2 HP by adding an old Delta Marathon motor and switching to 220V. When it ever goes, the 3 HP will get the nod. You will find the cabinet saw is better designed than a contractor. Since you mentioned a hobby, it's an option. If you were commercial, it's almost a must.
Regards...
sarge..jt
Get a thin kerf rip blade! First time I got one I thought my motor had doubled in horsepower!
oh yeah, keep it sharp, too!
Having the appropriate number of teeth in the blade is even more important when you're ripping at an angle -- the 1.5" stock becomes even thicker, if you know what I mean.
If you want icing on the cake, after changing blades, throw on a link belt. It won't make as much of a difference as the blade, but it will help.
