I have just designed and partially constructed a table. It’s 25 inches tall 12 inches wide top and 41 inches long with 3″ wide aprons. It is the precursor (?) to a companion table which will have the same height and width dim, only 54 inches long. I need some advise on attaching the top. I have seen advertised some metal clips that screw to the bottom of the top and are inserted into the inside edge of the apron. There must be some other way, such as gluing blocks to the inside edge of the apron, then screwing to the top with elongated holes. What is a good method?
Art
What I think you want are buttons. An elongated groove is (usually) routed into the apron to accept a tongue from the button that is screwed to the tabletop from below. A picture is worth a thousand words: (see below)
The buttons are easy to make by chopping up a rabbetted strip. Then make when you install them that you leave room for the movement of the tongue in that groove -the top to expand across its width.
Edited 12/5/2008 4:38 pm ET by Samson
Thanks. That looks like the way to go. I had never built a project like this before. Not even a M/T joint, and there are 22 of them.
I use figure eights. They look like two flat washers joined at their edges with countersunk holes. One side is screwed to the aprons, and the top is screwed to the other side from underneath.
They're easy to use, inexpensive, invisible, and allow the top to move slightly as it expands/contracts.
Sorry I took so long to reply. Sat, Sun and all. I have just found the figure eights in the Rockler catalog. Are These the ones you referred to?. They are listed as Deck Top Fasteners. I'm leaning toward them because I didn't have the foresight to prepare the aprons prior to assembling the table. (Less the top).
Art -Your timing couldn't have been better. I'm on my way back to the shop to install some figure eights on an end table I'm making. Pictures by this evening. - lol
Question. Does LOL mean 'Lots of Love, Lots of Luck or laugh Out Loud?
Art
I use it as "Laugh Out Loud", but you're free to interpret it however you like. (ROFLMAO) (Rolling On Floor Laughing My Azz Off)No pictures after all - my camera has died. It's almost four years old and has taken upwards of 1500 pictures and has decided that the batteries don't want to recharge anymore. Guess it's time for a letter to Santa. You'll have to trust me when I sa that the end tables sure look good though - lol.
Art,
Here is a good FWW article on this site:
http://www.taunton.com/finewoodworking/SkillsAndTechniques/SkillsAndTechniquesPDF.aspx?id=2349
I also use figure 8's. They're very easy to install, and work well, allowing the top to move.
http://www.rockler.com/product.cfm?page=786
There you go.
I didn't get to your message until I had already asked the question about the figure eights. I have just ordered them. Thanks to all for the help. I have been a "pretend woodworker" for about 20 years. This is my first real(!) project. Hopefully the second table will be easier.
Keep at it, and enjoy yourself. We all started out as new woodworkers at some point in our lives. Ask questions here. For the most part, you will find all the answers here.
