I’m sure this issue has been beaten to death, but I can’t seem to find the relevant postings: What should the proper speed be for a tablesaw blade? I guess this could be in RPM or feet/min. I have an old tilttable 14in. saw and I need to increase the diameter of either the driving sheave or the driven sheave (or both) to make sure the three belts don’t rub. I’m pretty sure I know how to calculate the effects of either, but I don’t know what the proper blade speed should be.
3,450 to 3,600 is typical. Such basic info is easily accessed by looking at spec info at sites such as Delta, Wilke etc.
Thanks -- those numbers do sound familiar. But, what about diameter? My 14in blade is going to be driving teeth into wood at a much greater rate than a standard 10 in blade, even if the RPM's are the same. I will go to manufacturors' sites, as you suggest.
The relavent factor is NOT the RPM, it is the feet per second of the rim speed. Every blade I have seen has had the maximum RPM printed on the blade. The larger the diameter of the blade, the less the RPM.
For a 10" blade, most blades should not be run over about 4500 RPM and most 10" saws run the blades between 3000 and 3500 RPM.
I would contact a blade manufacturer for the size blade you need and get the correct answer. You don't want little carbide shrapnel flying around.
Delta's RT40 is a 14"/16" saw. Specs state "Double V-belt drive can be set for speeds of 3000 or 4500 rpm for best cutting performance." (refers to arbor speed)
Use the manufacturers info to guide you. Blade manufacturers list optimum rpm. I use the techs at the manufacturers instead of forums for answers to questions.
I've seen a lot of direct drive saws that run 3,600 rpm that will take up to 18" blades.
http://www.northfieldwoodworking.com/tablesaws/4saw.htm
We generally recommend between 50% to 70% of maximum RPM as the best speed for Freud blades. That works out to around 3500 to 4900 RPM for a 10" and 2500 to 3500 RPM for a 14". This is based on the pretensioning of the blade and the expectation that you will be feeding by hand. Custom shops can make blades for different speeds/applications if necessary.
Charles M
Freud, Inc.
