A friend of mine and person I did a lot of business with died a while back. I ended up with a bunch of wood and hardware and his old Rockwell contractors saw. An inheritance you might say. I didn’t have much use for the saw, flipped the switch and it turned on so I pushed it out of the way and it sat there for the last year. So yesterday I had my tablesaw set up for a particular project and then needed to rip a couple of boards for something else I was doing. I put a blade in the Rockwell but when I started to cut a couple of pieces of 2x fir it started to cut and then it just stopped and buzzed. The last time I had a motor go out on a jointer I called the electric motor guys that I used to bring stuff to and they now wanted almost the price of a new motor just to tell me what was wrong with the old one so I just bought a new motor.
My son just purchased a house in the California hill country and it needs a lot of work and the plan is for us to set up a shop there to do the work and, well, I have this old contractor saw….so now I do have a reason to need it.
The question is what is the most likely cause for the motor to fail in this way in the event that I attempt to repair it? Other options are to just buy a new motor of course or , I do have a really beefy and heavy 3 horse motor that seems overkill for this saw sitting in my shed.
Likely a bad contact, open the starter box and clean it and check connections, same for the electric connections box on the motor. If that does not work, its the capacitor assuming all is free to move.
