I screwed up big time. Built a new workbench to serve as bench/outfeed table for tablesaw. Went to make a bevel cut the other day, cranking to 45 degrees – increased resistence hmmmm, why is my blade no longer parallel? Crap my motor is hung up on the workbench. When I went to bevel the blade the guard/motor hung up on the workbench and now my blade is out of parallel. The back is between an eigth and a sixteenth out of alignment. I’ve loosened the trunions on my saw (general int. 50-185) and have not been able to get it back to parallel, close but not close enough. could something else be bent/damaged/out of alignment? Thoughts?
http://www.deltawoodworking.com/index.asp?e=144&p=462
This guide might help you out.
Have you loosened all the bolts? If you have, it's better to loosen only three and leave one tight. Not torqued down. Once you get it close then tighten (not all the way) the others and then tap the table into alignment with a small hammer.
It might take a little time but this has always worked for me when I have had to align mine.
Hope this helps.
I did exactly the same thing with exactly the same saw. No damage but it did knock it out of alignment alot.....visibly noticeable. The alignment process for any CS can be tricky....don't give up. I ended up putting on a set of PALS on the rear trunnions, and recentering the front trunnions. "...Patience Grasshopper..."
I've loosened the trunions, but they "bottem out" before I can get it into alignment. I called Gen Int back and really nice guy informed me some of the trunions had the holes bored too small so there wasen't enough play to realign. He said he'd replace the part today and bore the hole oversized. If it happens General has my business for good. That would be incredible customer service.
YIKES!!!! Don't bore out the trunnion holes!!!!! Sheesh, I hope you got that message in time.
OK, what happened is that those two parallel bars (tie bars) that hold the assembly are now not parallel. I've experienced this personally and read at least 3 reports from others with the same problem (also from hitting the outfeed table with the motor).
The way to fix it is to get everything back into "shape" (configuration). I cannot tell you how to do this, sorry. I called Jet and got the name of their local tech. Took the saw body to him when he was at a local job and got him to do it. The saw came back perfectly aligned.
Adastra's link tells you how. For those who haven't looked at it yet, here it is in PDF form with diagram. Hint: Print it out and put it in a file. It's a good one.http://media.ptg-online.com/media/dm/Articles/FAQs/OriginalContractors-TypeSaws/20030108143706_Cs07m.TSD.pdf
forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
Edited 4/12/2005 12:07 pm ET by forestgirl
