Here’s the trick. All my 10 inch saw blades were dull and the sharpener got sick thus a two week wait. Had a few new blades for my worm drive and thought “why not? The arbors are the same.” So, I put the 7 1/4″ blade on the table saw and it slices through 8/4 oak like butter.
Anyone ever try this?
Mike S.
Sawick, been there done that. Always swapped smaller carbide blades to cut brass, aluminum bronze and phenolic
Alsodid it to rip recycled nail filled free lumber.
Try using two identical blades with a 1/4" spacer between to cut double kerfs in one pass. Stein.
if you can afford the loss in the depth of cut, it's a really fast, cheap way to increase the power of your saw. the smaller radius blades have better mechanical advantage. it's an old trick for underpowered contractor saws. one down side is that the teeth are moving slower (72.5% as fast as a 10" blade) so you're not getting quite the same cutting effect in things like plywood or in woods that tend to splinter when cross-cutting. in other words, it will cut more or less like you're using a blade with fewer teeth.
m
Mitch,
I understand the math of a 7 1/4 inch blade moving 72.5% slower at the teeth compared to a 10 inch. But what I think is gained is the much narrower kerf which translates to what feels like more power as you said. However, for cutting ply, couldn't one use a finer tooth or ATB blade? (assuming such a thing is available in a 7 1/4"? Funny thing is that in all the woodworking books I have read, this table saw trick was never mentioned (to my memory).
Mike S.
Steinmetz (as in Beer stein?)
Good idea to double up 7 1/4 blades. I think I might try that to cut some finger joints and maybe even a dado or two. Who knows? Maybe I won't get the 10 inch blades sharpened, given all the new experiments I can try with cheap 7 and 1/4 blades?
Mike S.
Sawick, Steinmetz was an electrical genius who worked for Thomas Edison. Growing up, My young friends nicknamed me that 'Moniker' because I fooled around with electricity and tools cars radio etc. My real name is Ed. Stein ryhms with Ryan. G'Luck, ED.
there's most definitely a number of offsetting factors in both directions- for instance, one already mentioned is using a contractor pack of el cheapo 7 1/4" blades to rip up salvage lumber. 10 inchers come in the widest variety and are generally available in far better quality (but you can get 7 1/4" blades from Forrest if you want to spend the $$), but if the smaller blades suit your purpose, by all means use them.
it's the same as any other mechanical engineering question. there are always tradeoffs and compromises.
m
