I searched but didn’t find this question posted anywhere.
I have a tabletop I need to glue up and I always have trouble getting it perfectly flat. Is gluing it up in stages an option?
For example, if the top consists of 4 boards, could I glue up boards 1 and 2. Then glue up boards 3 and 4. (That same night). Then come in the next day or so and do the final glue up. I didn’t know if clamping hard with pipe clamps on already glued up boards might affect the integrity of the already glued up boards.
Thanks in advance!
shawn
As long as you allow reasonable amounts of time for the glue to set prior to adding more boards, there should be no problem. Generally speaking, overnight is likely to be plenty of time for most PVAs, but as little as four hours is likely to be alright, especially for edge jointing on a plane (ie., not angled edges).
essdog,
You might want to consider using cauls in your glue-up.
Perfectly Kosher and, to be sure, there will be times when there is no other choice. Have done some 7-11' x 2' brick laid slabs of oak & walnut. No way to glue that up in one shot. .....................Do it.
Did it.
I glue up wider panels in two passes but have done all in one whack too(not a kitchen table width). It just depends on how wide clamps you get and your feel for the stock to glue up. I would caution you though. Even being perfect with cauls and alignment don't expect dead flat out of the box. I've been burned with this in the past even with good QS stuff. I now allow a bit extra thickness to final dimension and watch for a minor cup or bow and use the old LN #7 to knock her down and finish with either a scraper or good sander but thats just me.
The nine most terrifying words in the English language are, 'I'm from the government and I'm here to help.' - Renaldus Magnus
ess-d
have done this many times also. something that may help is that i clamp the joint at either end of the board with a deep c-clamp with two small squares of plexi-glas sandwiching the wood top and bottom. this helps greatly in keeping the ends aligned and helps somewhat with the middle area also.
i hope that made sense.
eef
Thanks Eef (and to all who replied),Looks like I got the green light on this one. All the FWW articles explain gluing up tabletops in one shot but I get frantic doing tabletop glue ups and its not like I need the tabletop done that same day.OK, here goes....
