I’ve been having a bit of a hard time cleaning up my wood surfaces after sanding. I’ve tried wiping down the surface with a cotten cloth and then air blowing the surface but there still seems to be small particles on the wood. I bought a couple of tac clothes to try. Does anyone know how long tac clothes typically last and can they be reconstituted by laundering?
I've never liked tack cloths. (Maybe I don't like tack cloths because I don't use them right.)
I use a vacuum followed by a spray with the air comressor. Finally a wipe down with with paint thinner removes any last bits of dust and show any hidden areas of glue or other defects.
My 2 cents, exactly that.
Paul
My microfiber tack cloth from Home Depot has been very effective through about a dozen usages (all surfaces loaded with sawdust). When it is loaded, I just rinse it in the shower. Personally, I wouldn't let detergent get near it; it's almost impossible to remove all the residual detergent, which might contaminate the wood surface.
IMHO compressed air is a poor way to clean a surface. First, it is a point source and so its effect is not uniform. Second, the dust goes into the air, to settle later in unwelcome places. Just by habit, I always vacuum with a brush attachment before wiping with a microfiber tack cloth.
And when you vacuum with the brush attachment, push it down onto the surface firmly. Even better suction.Gretchen
Thanks to you both. Great idea's
jim w
I've been following up a vacuum with Naptha-dampened cloth. I like Napth better than MS because it evaporates so fast. Tried one of the microfiber cloths for the first time a few days ago, and it seemed to work very well. One caution though, the microfiber cloth can pick up and hold tightly a piece of grit that might scratch, so be very careful and aware.
I have recently tried the "Swiffer" type dust cloth with pretty good results.
