What is the proper way to prepare a tack rag to remove fine residue of dust prior to applying water polyurethane??
Best to not use tack rags at all under or between water based poly coats as they have a reputation for causing adhesion problems. It probably warns against using tack rags on the can.
Wet a lint free cloth with water, ring it out thoroughly and use that instead. Follow behind with another clean dry lint free cloth if you need to. I use this method quite often if tack rags are unavailable between coats of other film forming polishes and varnish too where tack rags don't cause problems, e.g., pre-cat lacquer, etc.. Slainte.
I think I can help if you want Curly Claro Walnut. I just had a piece that size but 3" thick on E-bay and no bids on it. I'm not into selling my cherished walnut but I had a tree milled 4 yrs ago and am selling a few pieces to offset some my cost and work to get it.
walnut_charlie@hotmail.com
Charlie
