I’m making a relatively small project from white oak. I have the benefit of relatively large QS white oak cut offs from a previous project. This may represent the first time I’ve had the opportunity to layout pieces to take best advantage of grain direction and pattern. Previously I’ve accepted the grain as it exists relative to the most convenient edge. Looking for ideas, opinions, and especially references to articles. How do I recut these pieces when the grain i think I want isn’t relatively parallel to an existing edge?
To realign an edge I usually double stick it to a piece of plywood so the ply can ride the tablesaw's fence. Pop it off to rip the other side parallel.
Search this site for articles about the L-fence for another approach.
or bandsaw close to the grain lines you like, then joint a good edge, then rip parallel on the tablesaw.
You can also make cardboard cutouts of your desired pieces and then align them to pleasing grain. Then trace and do the above.
I've done this a lot and it is really helpful. I use a bandsaw to make the cut along the line I've drawn. What is not said is I make a hole the size and shape of the desired piece of wood in a bigger piece of cardboard so that I can see the grain pattern directly. Then I trace the perimeter of the hole on the wood.
I'm going to chime in, probably quite unhelpfully for the sliding table saw. Having a sliding carriage makes this sort of operation a snip.
I agree and this is where the Fritz and Franz jig really shines especially when dealing with smaller pieces or irregular shapes/edges. For those who have a sliding TS there are some good Youtube videos on how to make a F&F jig. Quite simple to make.
