I would like to build a tall case clock but have learned that the metal decorative dial plates that can be purchased with the movements typically measure 11″X15 9/16″. I’ve noticed that some of the manufactures of current limited addition clocks have larger dial plates, i.e. 12″, etc. Are these larger dials plates available? I would like to build a larger clock that a bigger dial plate would be more conducive to the proportions. I’m not having any luck with some of the internet providers having dial plates > 11″. I would imagine that current manufacturers design and make their own which is out of my expertise as a hobbyist. Thanks for any input!
Kevin
I'm a hobbyist also in the process of building a tall case clock. The movement/dial that I purchased are made to work together. There are pins on the back of the dial that slide in to movement and catches on the movement that lock it in place. The dial is not fastened to the case in any way. I suspect any new movement you purchase would be made this way. So unless you are in to metal working you may be limited in your selection.
I purchased my movement from Merritt's Antiques. They have a large collection of antique clocks , fascinating place to visit and I believe sell old parts as well. They may have a larger dial from an old clock you could incorporate in to your design.
Thanks for your input. I will explore Merritts. Can I ask what movement you are incorporating into your clock? I'm not set as of yet what to use, but would like to buy the movement before I begin construction. Thanks again!
Kevin
Kevin,
The movement I am using is the Keininger Flagship movement, don't have the model number handy. You should also checkout the Klockit website they have some very useful information on movements for tall case clocks. If this works the following is a link to an instruction manual from their site http://www.klockit.com/files/pdfs/Mechanical_Clock_Movement_Booklet.pdfGood Luck,
Gene
Tool,
David Lindow, in PA makes terrific reproduction tall case (and other) clock works, and provides the correct size dial plates with them. My understanding is that these are the same ones that Merritt's sells. I suggest that you contact him, he may be willing to sell you a blank plate, if you already have a movement.
David Lindow
527 Gravity Road
Lake Ariel, PA 18436
570-937-3301
Possibly Kathi Edwards of the Dial House in GA, may also be of help. She does beautifully painted clock dials, and it may be that she can supply a blank, or painted, dial to you.
The Dial House
3930 Brownsville Rd
Powder Springs GA 30127
770-943-5676
It might also be an option for you to cut out yourself, a dial in wood (old ones were typically white pine, with thin battens dovetailed across the back to hold them flat),plywood or masonite, or sheet metal (16ga mild steel) of the size you desire. I've done this, and it is doable. If you want a moving moon dial, I'd recommend going with David L's as it is a bear to do without the proper tooling (damhikt).
While it is true that old metal plates were typically attached to the front plate of the movement, and butted up against the inside of the hood, wooden dials were sometimes attached to the hood, and slid into place, then the hands attached to the handshafts.
Ray Pine
Ray (and other respondents),
Thank you for this information!! I'll get back to you with any further questions.
Tool
