Can anyone let me know the best way or tool to use for putting a tapered bore in a piece of cherry. It is a 2″ sq. block about 4″ long. The smal dia. is .615 and the large is .688. I currently chuck the block up in a 4 jaw chuck and put a 9/16″ drill bit in my jcaobs chuck and feed it with the tail stock. This works great, then I have a spiral reamer with a 1 degree taper that I put into the jacobs chuck and open the bore up to the above dimensions. This however leaves spiral groves in the bore. I need a smooth and acurate bore. I have changed speeds on my lathe from 500rpm all the way up to 2850 rpm. This is the way I would do it with steel but it does not seem to work in wood. Iam using a reemer designed for steel. Any suggestion would be welcome. Thank You
String instrument makers use tapered reamers of various sizes to make the holes for tuning pegs, tailpiece buttons and endpins. Try International Violin. http://www.internationalviolin.com
Henry
Thanks Henry, this put me on the right trail. There is alott of good information on this subject,
Jim
