Tapering Back Slats with Router Table
I’ve limited my Adirondack chair-building to the Norm Abram model, mainly because the back slats do not require tapering.
But after reading the recent Adirondack chair article (FWW 192), I’d really like to give Tom Begnal’s design a try. I think I can taper the back slats using my router table. I don’t have a table saw or a jointer, so these are not options for the tapering.
For router and router table operations, I typically consult the American Woodworker Woodworking With The Router book by Hylton and Matlack. They show a picture of tapering on the router table, with an explanation, on page 192. But no matter how many times I read this, it still isn’t sinking in.
Can anybody offer me direction on how to taper the back slats for the Adirondack chair using my router table?
Thanks.
Billy C.
I don't have the book so can't comment on their method.
With a couple small nails, tack on a straight piece of wood on the taper line you want to cut. With a bearing guided pattern bit, over or under type, make the cut. Repeat for each edge.
Can do the same with a router bushing if you don't have a pattern bit.
http://www.leevalley.com/wood/page.aspx?c=1&p=46171&cat=1,46168
Hi,
Wish I could help you with your ? concerning tapering on a router table since I have no experience tapering on the router table. I'm fortunate to own a jointer.
Tom Begnal's design is beautiful. I love the curve on the back of that chair. I just finished painting the one I build using his plans from the August issue of Fine Woodworking.
It was incredibly easy not to mention super fast using the jointer to taper those back slats! Wow! I was amazed. What a wonderful tip.
Wanda
