Has anyone found a task light that has a strong enough magnet that will stick where placed. The ones I have bought stick well when placed in the vertical position but don’t stick as well when using the side magnet or even on iron if it is painted.
I use these. The swivel magnet is very strong.
The little ones have strong magnets, too, and clips.
They charge fast, last a long time, and are very bright with modes if you don't need blinding. I've had them for a couple of years now, and they're like new still.
Although they are expensive for lights, they are high quality, and I would replace them immediately if something happened.
https://www.amazon.com/OLIGHT-Rechargeable-Flashlight-Magnetic-Emergency/dp/B0BKVWJMGT/ref=sr_1_3?crid=3A9HPVZ1CQ5P4&dib=eyJ2IjoiMSJ9.2Ji90EQ15d5kjCKiUvqi7n5DyRoIx7fNVT-UL1k1Y_uqwDqHy7HRiarpgz-2PHw806RnlujqjNR39jWC2eAiISaBOsGg56bFFOf-5WM6WmtYweKUb8PZQRnye_BJxE0eH-dU7QIauS6g073rKNsSBimPgcA8pNAH6YVtw-YLYRsHz4oBO1V5TU4jaJ4PoVZAd7kx7q45Daja6MeUC6Q6cRt_U3q0yCX3WLqS8hLvaJJJF5DaHrc1FdEClAC5wTJvLE_Ykl0vEB1aJzLFmV6e9Uw6M4ELQn01_YPmGxX94vY.wRlY55CDEAw5iCh-KlXbiNUEEMCcwtaRZlREZIYCvJk&dib_tag=se&keywords=o+light+swivel&qid=1718065948&s=hi&sprefix=o+light+swivel%2Ctools%2C98&sr=1-3
https://www.amazon.com/gp/product/B0CCJDRK76/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&th=1
Now that is indeed a clever approach. Will have to get one of these.
Harbor Freight has a new one I'm pretty impressed with. I took the clamp off the magnet as soon as it came out of the box, but the magnet is VERY strong.
I picked up the icon series task light from HF. Really strong magnet, 800 lumens. I can mount it sideways on a drill press or bandsaw with no issues. For my bench, I added a magnet on a 3/4” dowel, drop that in a dog hole, and stick the light on top of that. This light gets used almost daily.
Very happy with this:
https://www.woodcraft.com/products/rikon-led-gooseneck-work-light-with-magnetic-base-and-clip?variant=43401554296970&gad_source=1&gclid=CjwKCAjw65-zBhBkEiwAjrqRMCilS8PRGez73pP3tNoERGLcqkT06DPQPuFWuyFxNhMGl8V6OfX1NhoC8G4QAvD_BwE&gclsrc=aw.ds#product-details
Another option is a light into which you can fit a battery from any battery-powered tool range you have spares for.
I have a Bosch FL12 12V Max LED Worklight, for example, as I have a number of 12v Bosch tools and plenty of spare batteries that'll go in this light.
https://www.amazon.com/Bosch-12-Volt-Cordless-Light-FL12/dp/B00OKGAERO/ref=sr_1_2?crid=35CEK0T15B109&dib=eyJ2IjoiMSJ9.T31goZcfsWxwlQwNzEybDM9V5gO-5EIJRQDwpapkQAE17QOt-J-Fmvt7u7JcyS2eFxFN8FBJ01dJZCBXT4lD91d_xExjALwU6Y4F4mIhwF3kBOGuvU61mFrYZ2xM53PiG_kmXzjMBFzxyjEu55vyGUpSBT65ycz9pqhvkKf8P7dGQx0FInl5Rjp69G98sjaqMwNYK6bnLd7UqA65bdo-sz1Jt8QZwzGtj7TRyzZjFHsAiL3tAXCHO5U0EPOeAK_NMai4CjOP1rBrGFiL-tzl-eS1DYq0eJ7pLZqAVhvCTi0.Rgh9IIFjl7VjzMntuJz4wNUAYK4LxwrBOHUDcV1La2A&dib_tag=se&keywords=bosch%2B12v%2Blight&qid=1718119911&sprefix=bosch%2B12v%2Bligh%2Caps%2C166&sr=8-2&th=1
The more methods the light has for mounting in various ways, the better. A strong magnet is also important - some are rather feeble. Happily the Bosch fills all those requirements and also has a two level light output.
Thanks. I don’t think one light will serve each of my needs so I am going to buy a couple of these that ya’ll suggested.
