I am a self-taught woodworking novice and I plan on building a stand for a vessel sink in a bathroom with a steam shower. I am planning on using Teak and I am trying to confirm a few items about working with teak in this application.<!—-><!—-> <!—->
1. should I prep joints with Acetone or alcohol (what kind? isopropyl, de-natured, cheap vodka……..) or something else<!—-> <!—->
2. what type of glue to use? I have heard everything from standard yellow to titebond III to hide glue to Gorilla glue.<!—-> <!—->
3. do I need to put a finish on this piece at all since it is teak and indoors but will be exposed to some steam and possible water splash.<!—-><!—->
4. Since I do not have a dust collection system yet will a simple dust mask be protection enough?<!—-><!—->
Thanks in advance.
Teak exudes an oil that can make glue fail to stick. The trick is to either glue the same day with fresh cut joints or wipe down with acetone to remove the inevitable residue. In a bathroom, you would want a waterproof glue. Resorcinol, epoxy, polyurethane and Tightbond III are possible choices. The best long term experience I have is with resorcinol but that's mainly due to the fact the others were not available 30 years ago. I've been impressed with Tightbond III particularly the cost and ease of use.
Teak is one of those species that can bother some people. Often it's a skin rash. I'd stay covered up and try the dust mask. It does give off a fine dust when milling, I'd clean up as soon as possible.
You don't need any finish on the teak, that's part of the beauty. I have unfinished teak towel racks, 25 years of wet wash cloths and towels.
