Tearout when planing african mahogany
I’m a newbie, trying to handcraft a hall table out of African mahogany. My problem is tearout on the table top. Details: The table top is a single board about 15″ wide with a striking flame pattern (not sure if that’s the right terminology). Here is how I prepared the rough lumber: (1) flattened bottom with jack plane; (2) used srub plane on top to get desired thickness; (3) jack plane to flatten top and smooth out marks from scrub plane; (4) smooth plane. The problem is that even with the smooth plane (a well-tuned Stanley #4 with a very sharp LN blade) I get tearout on the top along certain portions of the grain. I’ve tried making the mouth of the plane as narrow as possible, sharpening the blade, skewing the angle of the plane, planing with the grain, across the grain, at an angle to the grain. It does not seem to make a difference. It almost looks like certain parts of the flame pattern contains grain that is less dense grain than other parts, making the less dense areas prone to tearout. Again, the tear out only occurs in along specific veins (for lack of a better word) in the grain.
Two questions: (a) Any thoughts on what the problem is, how to avoid it?
(b) Is there a way of filling the small tearout areas to achieve a smooth top that won’t be blarringly obvious?
It sounds like the grain's changing direction in the areas you're having probs with... Refer back to rule #1... always plane with the grain... It might help to increase the angle of attack on your blade; hone a 5 or even a 10 deg micro-bevel on the back of the blade. Alternativly switch to a card / cabinet scraper...
Mike Wallace
Stay safe....Have fun
Houston,
The text below is copied from Lee Valley's web site. This will solve your problem.
If you wish to finish the table as is, you would either have to use a filler, or a self leveling epoxy.
I am actually reading Lee's book on sharpening right now. Looks like I'll get to put that knowledge to use right away.
As for fillers and epoxies -- what do you all recommend? What is the least visible, most finish compatible method?
You can fill with clear epoxy (I use 5 min. epoxy) or thick super-glue. Or finish then use filler sticks applied with a hot knife. Mohawk makes some that are very easy to use. The problem with tearout is the rough surface that can be still seen through the clear filler. I've been successful in hiding these by smoothing the void with a small carving gouge before filling. Use a satin sheen finish and the fills will blend right in.
I had the same problem with an African Mahogany tabletop I was making. No matter what I tried, or how sharp the blade was it always tore out a little.
That weekend was the Houston Woodworking show, where I asked the Lie-Nielsen demo rep how to plane figured mahogany. He demonstrated with their low-angle jack plane, and still got a little tear out. "Sometimes tear out is unavoidable, and you have to clean up with a scraper," he told me. So there you have from a pro.
I am guessing by your name that you live here in Houston?
Dan
Thanks, I appreciate your response. Looks like I've got some quality time with my scraper coming up.
Yes, I am in Houston. I take it from your response that you are too. Have you found any good woodworking clubs/groups in town?
Houston,
"Two questions: (a) Any thoughts on what the problem is, how to avoid it?
(b) Is there a way of filling the small tearout areas to achieve a smooth top that won't be blarringly obvious?"
a) The "problem" is that there are situations and conditions where a steel blade, no matter how well sharpened, angled and otherwise "tuned" cannot shave the wood tissue cleanly and some tearout is inevitable.
You can avoid the problem by avoiding the failed technique.
A cabinet scraper correctly sharpened and bowed between the thumb and fingers is a joy to use in such situations. It takes a little experience to properly sharpen a scraper's edge and LN, among others sells all the equipment needed (the scraper itself and a hardened burnishing tool) and good descriptions how to do it. Once learned, it is very easy, and takes just a few seconds.
Also, have you heard of sandpaper (sarcasm alert)? This will also do a beautiful job, used properly.
b) No! Any "filler" you use will ultimately be visible as a departure from the surrounding wood texture and grain pattern. Which brings us back to either the scraper or sandpaper. You will need to bring all the surrounding wood down to the level of the deepest tear out in order to "remove" it. A cabinet scraper is best used to provide the final surface on wood already prepared by planing. It is not meant for heavy wood removal. But it is up to the task with lots of resharpening. Be prepared for fatigue in your thumb and hand muscles. And lots of HEAT!
Sandpaper can also do the job. Start with VERY coarse and don't rule out using a belt sander. But a ROS will do a very good job. Get the entire top perfectly level and free of tear out holes with the coarsest grade FIRST. Then the rest is easy, using progressively finer grits to remove the scratch pattern of the previous until you're satisfied with the result.
Rich
HH,
In addition to what others have already contributed, I'll add a recommendation that you wet-sand the top.
I typically wet-sand with Liberon finishing oil, but it's the underlying premise that's important to understand: after you've scraped and sanded the surface fair and flat through 220-grit, wet-sanding will create a slurry of oil and sawdust that will pack the pores and areas of mild tearout. Since you're not introducing a foreign substance like epoxy, and you'll be wet-sanding the entire top, it will have a uniform luster and texture when you're done.
I've attached a snapshot of a piece of wet-sanded African mahogany if you're interested.
Good luck,
-Jazzdogg-
Houston, Jazz got it in one.
You can also get the same result by wet sanding using mineral turpentine-dries out chopchop so you can follow with a sealer like the Zinsser Bulls Eye de waxed shellac followed by whatever.Philip Marcou
Thank you all very much for all the feedback and advice. I'll post a follow-up message to let you all know what I did and how it turned out.
