Two weeks ago, I had a walnut tree milled and stacked the lumber under a lean-to. The other day I returned to find termites crawling on the lumber and starting to penetrate the surface. Does anyone know a good treatment that will not effect the finish of the wood?
If there is no ground contact, I think what you have is what are called "dry wood termites" (I had them in a home once, not fun!). Here's a background article from my alma mater U.C. Davis.
For houses, they fumigate with Methyl Bromide, nasty stuff but works like a charm. Not for the DIYer though.
What FG said only applies to certain parts of the country. Since you have not filled out your location on your profile, everyone will have to just guess, rather than give you real meaningful information. Please do that now.
For the rest of the country, all you have to do is treat the soil under the stack to kill termites. You should be able to get something at any good hardware or farm store.
"For the rest of the country....."
FG lives in the extreme Northwest of the US. I think all of the South has termites that are not subterranean.
Following up on Keith's point, click here for an incidence map of drywood termites. Note that the big white area is "Rare", not "non-existant". My home was slightly outside the Moderate zone in Northern California, but that didn't protect me, LOL.
I see your user-name Down-South as a pretty good indicator of your geographical location. Right? I used to be a down-souther m'self, but lost the accent some time ago.
Thanks for the info forestgirl. I want to reply to you and KeithNewton in this message. I'm from North MS. I didn't explain how I stacked the wood earlier. The boards are above a concrete slab foundation. I put down pressure treated 4x4's and stickers. Then, I proceeded to stack that walnut and sticker it. Thanks again for the info given and any more you can give.
So there's zero ground contact. They have to be drywood termites I'd think (no, I'm not an entomologist). Sprinkling stuff on the concrete won't do any good. Are you sure they are boring into the wood??forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
The only zero contact that I can think of is if it is a boat. Everything rests on something. I'm thinking you mean wood against earth. Actually subterranean termites can form a tube and go up a story or two of solid concrete or concrete blocks before finding any edible parts. They must have a way down back to the ground though or they will die.
Edited 10/19/2009 12:59 am ET by Tinkerer3
Don't trust a concrete floor, I live in Alabama, darned termites made it through hairline cracks in the shop floor & ate the wood out of the eye in a sledge hammer and a pick. They also came thru the floor and into a styrofoam ice chest to eat a bunch of magazines I had stored in it. . . My workbench legs are on pieces of flashing, big tools are on fiberglass roofing shingles and a slab of hardie board.
It's a constant battle.
Are you sure they came in through cracks in the concrete floor? You live in an area where a non subterranean termite can walk in through the front door and start chewing. But yes, subterranean termites can go through very small cracks in concrete.
Edited 10/20/2009 9:37 pm ET by Tinkerer3
bora-care, it's basically a boric acid and ethyline glycol mix. totally safe
"...and ethyline glycol mix. totally safe." Beg to differ. Ethylene glycol is very toxic to dogs and cats. Cats may not be likely to eat the stuff, but some dogs lick up anything they find that looks remotely digestible.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
the way it is mixed you wind up with a chemical reaction and the resulting product is non-toxic
"ethylene glycol"
A very toxic compound. I can see where you could mix it with other products to make it unpalatable or even dilute it down to the point of less toxicity but how could you mix it to be non toxic? Any way, I would suggest you not drink it.
"the way it is mixed you wind up with a chemical reaction and the resulting product is non-toxic" Mr SQL, re: the toxicity of BoraCare -- I had a little time this afternoon and took a look at the MSDS for BoraCare. The quote below is from that document:
I hope you don't feel I'm pickin' on you. It just that it's very important, IMHO, to provide valid information when it comes to comments about safety in a widely-read forum such as Knots. I will stand by my caution about having this stuff around pets. I have no idea if it's as "attractive" to pets as anti-freeze is, perhaps not, but I'd err on the side of caution myself. You'll notice that they recommend inducing vomiting for ingestion by a human of more than 1-2 Tbs of the product. For a pet, it would be a fraction of that. It's pretty apparent that BoraCare is not a benign product.
Edited 10/21/2009 9:30 pm by forestgirl
Thanks for the answer. Could this treatment mess up the finish later on?
