Does anyone know of a method for aging wood to make it look like it has been out in the woods for years? I’m not talking about the color but the texture where the grain pattern is still prominent but the soft wood between has worn away. I thought of sandblasting the wood or maybe pressure washing it to remove the softer areas. Any Ideas?
Sandblasting will work on wood that has alternating bands of hard and soft wood, but the texture won't look like weathered wood, the contours will be soft. Never heard of it being done with a pressure washer.
On pine, and maybe on some hardwoods, you can scorch the wood with a propane torch and then wire brush it in the direction of the grain, but the color will be darkened considerably, you won't be able to make it look weathered gray. If the wood is quite soft you could try just wire brushing it.
Hope this helps, John W.
I have heard, but not verified, that some of the less honorable antiques folk in England will "age" a piece of furniture by covering it with chicken manure for a period of time. Oh my.
Actually, your pressure washing idea is a pretty good one, but I suspect (based on what's happened to our deck) that having the lumber get very, very wet for awhile would help.
Maybe I'll just soak a few test pieces and then have at them with the wire brush first. If that doesn't give me deep enough grooves I'll try the sandblasting on the soaked wood. Thanks for the input.
I've used a combination of fine (brass) and course (steel) rotary wire brushes with an angle grider to pretty good effect on a few picture frames. Works especially well followed by several coats of milk paint and additional distressing. A buddy cobbled together a machine with brushes ganged together sort of like a drum sander to do a lot of this. I've wondered about subjecting the finished piece to soak, freeze and thaw (sunlamp) cycles.John O'Connell - JKO Handcrafted Woodworking
The more things change ...
We trained hard, but it seemed that every time we were beginning to form up into teams, we would be reorganized. I was to learn later in life that we tend to meet any new situation by reorganizing; and a wonderful method it can be for creating the illusion of progress while producing confusion, inefficiency, and demoralization.
Petronious Arbiter, 210 BC
I recall seeing an article a few years where boards were placed under a chute at a grain elevator/silo and the corn/wheat or whatever removed the softer wood giving them a weathered appearance.
A small shop built tower that used dry sand would probably also work and you can control the speed of the sand and hence the rate of material removal. Downside is that it would probably take a lot of sand, and a LOT of shoveling to abraid a significant amount of material.
