sarge suggested an elaboration on the subject of the many small fixes, patches and dutchman we have all become expert in applying. maybe this discussion could spin out into the wisdom we’ve all gleaned from fixing our mistakes year after year.
(that sounds a little depressing…)
i have had to fix everything i have ever started out to learn. for example: my partner and i were to deliver an 8’x4′ conference table to a nest of lawyers on the west side of LA. this delivery would result in, among other things, the payment of my rent. while carrying an armful of pipe clamps across the shop i tripped and inadvertently tossed a four footer onto the very expensive black laminate which made up the center of the table.
the next several hours were spent learning much about seam-fill and repairing laminate, info that, to this day, although expensively gained, remains valuable.
after much futtsing about, buffing and dulling the lawyers made out the check and we made our escape.
eef
A "nest of lawyers"? I thought they traveled in packs and lived in dens.
Probably as in 'nest of snakes'. They have a varied habitat, in water sharks won't touch them - professional courtesy.
But will they touch sharks?
Only if there is a buck to be made. Iffen I was a shark I'd be careful, I believe sharkfin is expensive.
I had just finished installing a kitchen countertop in a small kitchen. The plumber set his bucket of tools on a piece of cardboard on the top. A wrench fell out of the bucket and put a dent in the laminate. This was not anything you could fix with seam filler.
I made a template for a router and glued in a silver dollar,the old type not the Susan B Anthony type. A dab of varnish keeps it from tarnishing. The plumber and the homeowner came to a financial agreement I understand.Would have been nice to have gotten something extra from the plumber for my work.
mike
mike,
a silver dollar dutchman and a monument to, memorial of someone's error, all in one. good story.
eef
Had a similar problem, electrician dropped his 18v electric drill while installing spots over a laminated solid timber benchtop. It landed drill bit first (thanks Mr Murphy) and dug a deep gouge into the timber. As it was to be a gloss finish any patching would stand out like the proverbial.I routered a 1/4" deep trench the width of the timber board used in the laminate (luckily the benchtop was laminated using random lengths), inserted and glued a piece cut to size, sanded flat and when finished no one knew. The poor old electrician had been expecting to have to replace the whole benchtop and it was worth a couple of freebies to me.
"laminated solid timber" What's this stuff? Do you get it where they sell "solid particleboard?"
Usually a bench top made up from selected species of timber (hardwoods mostly). 2x1s or 2x2s in random lengths with shot ends, laminated together with epoxy cement to form a 2" thick solid timber board, 2ft or more wide. They can look beautiful when polished. Also used to make beams of incredible strength for exposed beam work. Don't know where you get it the US. The ones I use are manufactured in Australia.CheersBruce
IslanddogCheck out this websitehttp://www.spec-net.com.au/company/dgi.htmBruce
I often fret over my own projects--furniture for myself and family. I don't think I have built a piece yet that doesn't have some sort of 'coverup' on it somewhere.
I don't feel so bad, however, after touring Frank Lloyd Wright's own house and studio in Oak Park recently. In the dining room is a large built-in mirror that has wood trim around it. The trim was cut 1/2 inch too short. To solve the problem?--1/4 inch patches on each corner, mitered and fitted. They weren't too interested in matching the grain either.
door,f.l. wright, the man with the leaky roofs...same for me, nothing has ever left my shop without some kind of fix, patch or band-aide. that is sort of the point of this thread, how we grow, improve and learn by how well our mistakes are remedied.
eef
I once mounted a new exterior door in an apartment - college students. It was mounted perfectly in my book. At least it was the best one I've ever mounted. When the kids left some five months later I replaced the door with another new one and didn't do nearly as good a job. Oooh, college student rentals!
