Hello members, Im new to this so forgive me if i sound silly.
I would like to build 2 vanity cabinets for our b/room. My question to the members is: what type of lumber do i use if the entire cabinet is going to be painted/sprayed. We are looking for a high gloss finish.
My first thought was MDF board ?
All suggestions will be welcome
Many Thanks
woodyman
Woodyman,
MDF would work, fastened to a frame. Might I suggest, however, using 1/2" birch plywood fastened over a poplar frame. These ready to use materials are available at your local home building center.
They may even be willing to make a cut or two on the plywood for you if you know what dimensions you need. I also suggest making your vanity cabinets taller than the traditional factory build ones which are around 29-30" and turn out to really be too low for most people. I recently made mine 34.5 inches. Think about it. Don't forget a little toekick too.
- Woodshepherd
I usually use 3/4 birch ply (no frame needed) with poplar, or brown maple for the faceframes and doors. The back could be 1/4" luan or birch. That's my paint grade recipe with the materials available in my area.
Thank you GRW your suggestions are most appreciated. I will let you know the outcomesoon I hope.
I am with GRW re 3/4 birch and poplar/maple fronts for paint grade.
I would be leery of MDF in a BR due to the moisture issue, but I must admit I have little experience with MDF.
Edited 2/28/2007 1:02 pm ET by TWG
Hi woodyman,
If you are making frame and panel doors , mdf makes great paint grade panels . I also like Brown or Silver or Soft Maple for face and door frames and drawer fronts . Birch ply can be used for the cabinet ends and such but , I have found that Maple ply is smoother and has little or no broom grain compared to Birch , it really paints up nice .
good luck to you dusty
I'd use 3/4" paint grade ply--typically birch. There's a P/G ply made in china making the rounds (called "sandeply and at HD); it looks like it uses a super thin layer of luan and the grain doesn't fill all that well, so I recommend avoiding it. Maple is twice the price, unless you can find cheaper rotary cut veneer ply.
IMO, I'd avoid MDF for a bathroom cabinet. A vanity will get wet and MDF falls apart when wet.
Pondfish ,
Totally agree with not using the China ply products at all , but honestly a decent paint grade or shop grade of Maple may only be a few dollars more than Birch in a similar grade , but certainly not double .
dusty
I use mdf all the time for cases. I don't use it for face frames or the rails and stiles for doors but do use if for panels. I have never had a problem with moisture even in basement bathrooms where moisture is always a problem. As long as you have no exposed or machined edges it paints well. (the edges can be sealed or you can use joint compound to seal them if you need to).
I just did something similar by building closet organizers for the kids' bedrooms.
I used 3/4" birch ply and 1/2" birch ply. Both sheets were picked up from the local HD. My local HD is always willing to make cuts in the ply for me, so I give them a dimension 1/4" larger than needed and trim to fit back in my shop. Their cuts aren't very clean and their accuracy is within an 1/8". But there's no sense manhandling a full sheet of 3/4 ply if I don't have to.
After cutting to size, I sanded to 150 grit with the ROS. Primed and applied two coats of Behr paint. I used a 4" smooth surface foam roller. If you're at HD, it's the model with the 1/4" stem going into the pad.
All in all, it looks great and the only texture I see is from the roller, not the grain of the wood.
