Hello all members,
I’m a new member and very new in woodworking.
I’ve just finished building wall-mounted rack from “western pine”, maybe..
not very sure. My problem is the sap keeps producing sticky liquid the moment I
applied first layer of shellac. I cleaned the substance, and applied
three more layers of shellac, thinking that I can stop the liquid from comming out.
I was wrong, the sticky liquid still came out the next day after I fixed the rack to
the wall.
Any idea why? Will it eventually stop by itself?
Masrol
Shellac is the best sealant for blocking things like sap and stains but, sap will find it's way out. You must have used some construction grade lumber that wasn't dry. Now that it is in the house, the wood thinks it's Spring. Some pine can bleed forever but it is more prevalent in pitch pockets and knots. Did you notice that the surface was sticky when you built the piece? Sappy pine would have loaded up your sandpaper quickly and your hands would be stained. The surface would be grainy feeling due to all the beads of dried sap. If the lumber was like this, it will slow down over time but it won't completely stop anytime soon. It will wipe up with a clean rag and just a touch of mineral spirits. If this doesn't clean it up, there is another problem.
Since you describe the problem starting with the first coat of shellac, could this be the issue? Did you wipe down the boards with anything, have fresh shellac or add anything to it? Alcohol doesn't activate sap like mineral spirits would. I think you just made a bad choice in lumber.
Hi hammer1,
Thanks for your opinion.
For your info , the surface was very clean and well surfaced (S4S).
I bought the stock from a very renown D.I.Y store. The 8" X 36" X 3/4" board was nicely wrapped separately for each board with transparent plastic wrapper. I did notice there are about three saps on that particular board. All the saps are through on both sides of the board.
What I wonder is why the problem happens to one sap only and not to the other two. I did not wipe the board with anything before applying the shellac. And I used premixed shellac without any additive. My 1st intention is to put lacquer as the final top coating to enlighten the shine. But I am afraid it may become worse. I hope that liquid will not cause any harm since that newly built rack is right in the cooking area.
Masrol,
KUL, MY
You are probably dealing with pitch, also called resin, in the wood. Being organic, some pine has much more pitch in it than the average board.
Kiln drying will typically harden the pitch in the wood, but a board with larger pockets of pitch can still weep pitch even after being kiln dried. As the first poster suggested, there is no good treatment for this, the wood will possibly leak small beads of the resin for many years. The beads usually appear in hot weather and will typically harden on the surface in a few days, after which they can be lightly scraped off with a cabinet scraper.
I have a pine chest that's fifteen years old that still has beads appear on its surface every summer. The best way to deal with this is to give the piece an oil finish that can be lightly scraped and touched up with a wipe of oil as needed. Shellac will seal some pitch in, but isn't effective with actively weeping wood.
