Planning on using a pattern template, and am planning on using a 1/4” template. Is that a safe thickness?
As long as the bit bearing is well in contact it should be plenty thick. If you are using a rub collar (like the porter cable style) make sure the collar is shorter than the template is thick. I've cut down most of mine over time.
As MJ has stated the answer lies in the bits you use and the cut you are trying to make. I generally use thicker templates because most of my top bearing bits are designed to cut deeper than a quarter inch so they won't work with 1/4" templates many times. Think of it like this, if you want to cut a 1/2" deep groove and your top bearing bit has a 3/4" cutting edge you pilot bearing would be above the template and useless. In another scenario if you want to trim a 3/4" thick work piece to a profile defined by the template and used a 1" cutting edge top bearing bit it would work as long as you can make the cut in a single pass, probably necessitating rough trimming the work piece by some other method.
I would plan on using very short guide bushings and appropriate up spiral bits if it was me or thicker template material the chance of mishaps is greatly reduced.
"What we have here is a failure to communicate" -Strother Martin in Cool Hand Luke. What are you planning on using for guide bushings; Porter Cable style held in the router's sub-base, or a guide bearing on the bit? If the later, where is it mounted; at which end of the bit's cutting surface - shank or tip end? Are you planning on hand holding the router, or putting it in a router table? Answer these questions first and then an answer should appear more obvious to you.
Thanks to everyone for their info! I appreciate it.
I am a fan of 3/8" Baltic Birch for templates.
Most of my bushings and bearings are 1/4" so I find this works well.
Sometimes I make a template of 3/16" hardboard and then use that to make the 3/8" template.
1/4" templates are kinda single use, but the 3/8" can make multiple parts.
Nothing in and of itself wrong with the 1/4 inch, though would use baltic birch at that thickness rather than MDF.
As esch said, you do sometimes need a thicker one.
One thing to watch with thin templates - they can flex if they are long in comparison with their width and this can be enough to throw you off significantly. I recently made a set of nesting curved pieces for a queen sized bed head. I had a total nightmare until I realised the failure to fit was due to template (9mm mdf) flexing. In the end I screwed the template onto 19mm material and copied the template. The thicker stuff worked a charm.
That sir, is the most useful tip or recommendation I have received. It makes practical sense. Actually, I was thinking about doubling the1/4” mdf. The pattern is kinda hard to make out of thicker material, that’s why I was using Mdf. Anyway, I do thank you for your kind and useful information.
You say the nicest things! - Use lots of screws.
