Looking for plans to build a thickness sander. I was informed there was plans in the FWW. Upon searching, the only thing I found was plans in the Mar/Apr 1980 issue #21. “low tech thickness sander…home built machine is accurate and cheap” unfortunately this issue is no longer in print.
Can anyone help me here with this issues plans or any others??
Thank you.
FWW 58, May/June 86, pp. 54-57, by S.R. Cook: wood frame, threaded rod/bicycle chain raises table, sanding drum made from steel pipe (metal lathe). This article may be included in Taunton's "FWW on Making & Modifying Machines".
