Has anyone ever used a thumbnail molding plane on the stiles and rails of cabinet doors?? I want to build a shaker style cabinet and would like to try using a thumbnail plane to make the thumbnail on the inside edge of the frame…….
I just did that, but I used a #78 rabbeting plane to make the little fillet, then a block plane and scraper to make the curved, thumbnail part. Worked fine and quicker than I thought it would be. Use a little piece carved out with a gouge that is like a "negative image" of the thumbnail profile to check progress all along the piece you are shaping. I believe this "checker piece" is called a "mullet."
Good stuff. Quite fun. Even though I have four routers, on the fun scale doing this stuff with handtools is a "ten" and using a loud screeching router barely makes it up over a "five." I'm in the market for a few different sizes of thumbnail molding planes as well.
where do you find thumbnail molders?? what size 1/4",5/16"??
Patrick Leach had a couple Thumbnail molding planes on the May tool list - I passed on them and have fretted over that decision to a small extent - http://www.supertool.com . Other than that, I would say you buy them anywhere you find molding planes - ebay, "the best things" (I forget the web address), old tool dealers, http://www.mjdtools.com , etc.
Good luck pal
Oh and you could build your own molding planes - I haven't done this yet, but plan to. Doesn't seem like rocket science, or anything. I know just enough about wooden planes, metallurgy, and plane building to be considered dangerous.
Edit: The two thumbnail molders Patrick Leach had listed were 1/2" and 7/8" - more for the edges of tables, tops of lids, stuff like that.
Edited 5/18/2004 10:20 am ET by Ed from Mississippi
i found another website that might interest you on this subject...http://www.comteck.com
