I posted this at breaktime and ain’t got a peep out of anyone so I’ll try here.
I would tighten it to the high end of the recomended torque range. If you leave it loose enough to slip it may weld the washers to the blade then you will be replacing both.
The Professional Termite
Would your "pretty snug" qualify as my "impossibly tight?" If so, it's probably overkill. My understanding is that the threads on the arbors of all saws are directed the way they are so that the blade will not loosen when it's spinning. With tablesaw, in a discussion not long ago here, it was pretty clear that we don't need to muscle the arbor nut down overly tight.
No I don't think so....I can loosen the nut with a little smack on the wrench with my palm, but I'm going to loosen it some. Maybe somebody should talk in terms of torque settings.
"Maybe somebody should talk in terms of torque settings." I thought somebody (Trialnut) did. Or did you need the actual ft-lbs?forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Well yes what is the actual foot pounds torque recomendation? Who gives out this info? Makita?
I suppose if it's an important spec that they expect you to use, it would be in the owner's manual. forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
I ride and work on my own bicycles and some parts are getting to the point where the manufacture is recommending torquing the bolts.
Maybe this is a tendency in other areas as well.
Trying to build ever lighter machines would stretch the capabilities of the fasteners.
you were pretty fortuninate to find a dealer that new your solution to your problem. I use to work for Makita and heard that problem many times and everyons said that the arbor was bent , and needed a new armature. The inner & outter flange will warp after many years of use. The slide compound saw is a great machine, but maintain it with makita origional parts , and it will last you more than another 7 years. Good luck
thanks Ben
