After finding out that all the large cedar stock I have access to is either green or air-somewhat-dried I’ve been hankerin’ for a moisture meter. However, the economy being what it is these days, the well is pretty dry for WWing funds. Just ran across the Timber Check moisture meter on sale at Highland Hardware. According to the description it reads “moisture content in 1% increments from 7% to 12% then skip through 14, 18, 22 and 25% for air-dried to green wood.”
Now, this seems sufficient for my current needs. Does anyone have experience with this particular meter, opinions? Also, how eager are the lumber guys going to be to let me go around poking holes in the lumber? How deep do the pins need to go and what areas should be poked??
Sorry, I’m clueless about this part of WWing!
Edited 7/15/2003 1:30:54 PM ET by forestgirl
Have had one for several years, they are good for the task, the pins don't penetrate very far as mine is hand held and can't drive it deep. the pins will bend if too much force is used. the only fault i have with the unit is that one may forget to turn it off after use - it has a light to indicate power. repeatability - sometimes one will get readings that differ by %1 in the same piece of wood and same spot by repeated jabs. Instructions are good and comes with tables to compare movement and convert to standard temperatures.
Thanks WC, that's excellent info. I can deal with 1% variability I think, and I'm well-trained to remember to turn things off -- my digital calipers and a specialized calculator I have at work both require that. As long as it's not easy to accidentally turn it on! Is it???forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
FG: i keep mine in the original tube container. the switch is a dial with click stops. I have replaced the battery once because of some idiot who forgot to turn it off. extra pins are available, and there is a plastic cover for the pins, in case one needs to carry it around.
FG,
I did a bit of research on moisture meters about 4 months ago. You'll recall the article last year in FWW that went into some depth...however, the timber-chek was not in the article. There were some good reviews of the TC...as I recall the accuracy was there. However, guess who has two moisture meters....and knows how to use them...Sarge...I'm sure he'll be on shortly to answer all....
I think if you hang your engagment ring from a string over the wood...N/S movement indicates male wood...E/W = female.....lol
BG, if I put an E/W piece of walnut and a N/W piece of walnut in a dark corner and leave them overnight, will I get more walnut???? LOL!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
