I’ve decided that it is time for a DC now and would like to hear some opinions. I’ve had my eye on the Grizzly G1029 it is 2 HP 220v 13 amp and 1550 cfm. I have the Grizzly 6” jointer and have been very happy with it. The DC has a 6” inlet with a 4” Y fitting and also comes with the chip separator for $300 with shipping. I’d like to stay around this price range.
I will connect the DC to the TS, jointer, band saw, router table, and planner (as soon as I get itView Image). The longest run it will need to make vertically is 6’ and horizontally 35’-45’. Is there anything else that I should look at? Does anyone else have this DC? Thanks in advance.
A 2 hp dust collector will not have much suction after 35'-45' of tubing, probably not enough to make it useful. You will have much more suction if you could limit yourself to a much shorter run, say around 10'. you could do this by wheeling the dust collector form machine to machine, or you could get a bigger dust collector that could handle a longer run. If you do a search there is lots of information on setting up dust collection systems on this forum which may be helpful to you.
FM
Agree with Andrew. Also, the woven cloth bags that come on most DC's are useless. You need felt bags if you don't go to the paper type filters. Figure that in with the cost of Delta. I think around $75.
Take a look at Penn-State as they come with the felt bags. Here you go:
http://www.pennstateind.com
Good luck...
sarge..jt
Agree with Sarge. My DC (Jet) had the standard bags and was a great chip collector but sent the harmful dust right out into the air. By the time I added a 1 micron bag, I could have had a larger PennState for less money.
Jim
I use a Jet 1 1/2HP, 1150 CFM DC that works great on tools up to 50' away, so I think your Grizzly should be fine, if it works as they say it will. I've always been skeptical of Grizzly because of their prices...
Anyhow, I have a Powermatic 64a open stand contractor's saw, DeWalt benchtop planer, and Jet 12" bandsaw connected with blastgates to my DC, and the system works great. The planer is about 50' away from the DC, which has a cyclone can/lid sitting next to it, and almost everything gets sucked into it. I love it!
I might get better suction with a cabinet saw, as my 64a has an open back that probably costs me suction. But that's why contractor's saws are cheaper than cabinet saws. Oh well!
Make sure and do your research about dust collection, and don't forget to ground your system, sealing wiring holes with silicone. It's not that hard to do, and will help you sleep better if you don't have to worry about being blown out of your shop by a static electricity/sawdust explosion.
Rob
Please check the threads and literature on grounding. I sleep just fine (if I'd get out of the shop and go to bed) without messing with grounding.
FYI,
Jim
Jim,
I read 'em all, and decided to ground my system just in case. I've got too much to worry about with a new house, a full time job, and a wife with plans for an entryway table, two fancy bookcases, and an entertainment center.
To each his own!
Rob
I have a Grizzly 1029 unit and am very pleased with it. I however roll it around on its wheeled based and use a quick disconnect fitting to attach it to the equipment I need it on. It has been a very reliable machine and works well. I would purchase it again.
jb
Since this is a more or less general thread related to the subject of dust collection, I'll venture a side question if I may....
Would I be correct in assuming that if one installs the dust collection system *outside* the shop, the issue of fine dust filtration becomes more or less moot. That is, assuming 1) you don't mind having fine dust accumulate around the outside of the shop and 2) if one deals with the aspect of having the heated air in the shop sucked out during the winter.
As for (1), my new shop, when built, will be in a rural setting. The shop is well away from the house proper. The DC machine will be away from the shop windows and/or doors. And no, I don't care if the fine dust settles on and around the DC machine area.
I'll find a way to deal with (2).
I'd rather spend the money on air volume and velocity (read suction power) than high filtration stats.
Thanks....
Dennis in Bellevue WA
woodnut@anatechsys.com
I would agree with that assessment. Wish I could do that here but winters are too cold and summers are way too hot to move all my conditioned air outside.Tom
I came up with the same conclusion.
But, here in Vermont, our winter months this year have made that idea
no good.
The DC pulls too much warm air out.
My solution was a y connection with 2 gates.
One side goes out back for the warm months, the other goes inside to
a filter hung on the ceiling for the winter.
Problem solved.
Jeff -
My DC sets outside, but I live near Houston TX. Were I to live further north, I would build an enclosed space for the DC with return air vents back into the shop. Those vents would have to be well filtered and would need to be a large size. That, in addition to having the better filtering bags. Having my DC outside here allows me to use the cheaper bags.
I suffer a little in the summer with this setup, but I rarely have the DC running for more than 30 minutes at a time.
Dennis
Also agree. The problem is as the other posters stated, pulling the heat out. Other than that...great thinking.
sarge..jt
Thanks for all of your input. Looks like I have some more research to do.
