A couple weeks ago I made out of aged cherry a table with tapered legs. On the face of one leg was a resin pocket. Before wiping on tung oil, I decided to fill the hole with epoxy tinted black. I had seen this done on This Old House for defects in mesquite. I used the only epoxy on hand, Minwax, and mixed in black fresca powder. The epoxy was a glossy jet black, and when cured the surface retained the glossy jet black color. When I began carving away the excess however I found that the interior had turned a medium grey.
Does anyone have a successful experience tinting epoxy, where the cured interior color remained the same as the uncured color? If so, what brand of epoxy and what coloring medium? Thanks.
We use same epoxy, but use a powdered aniline colorant.Mohawk or Behlens works well and we mix the powder into the epoxy in a paper bowl to get good color dispursment.
*I've had good luck using a very small amount of powdered graphite. When mixed in well, it turns the epoxy a uniform black color.
