Tips on buying used jointer/thicknesser
![](https://secure.gravatar.com/avatar/41de395afefaa0f47c34063fb3386476?s=52&d=https%3A%2F%2Fimages.finewoodworking.com%2Fapp%2Favatars%2F200x200%2Fi.png&r=g)
Hello everyone,
My name is Mike and I live in Greece. I’ve been reading the forums the past years. I’m into part-time woodworking from 2010 constantly building my workshop.
I’ve been mostly building small furniture and collections stands with mostly hand tools and when a machinery was required I visited shops around me to work on them.
Now days I m moving into a much bigger shop and I’m looking to buy machinery to fill it.
I found an offer for a industrial grade Casadei FS50 combination planer/thicknesser from late 80’s. This is a real deal if the condition is right since is a 5.5kw 50cm wide machine and mortising unit offered at 1000euros(around 1100$). Im ready anyway to replace bearings and drivebelts, but I would like to know what to look for when I go see it in person.
Iron cracks are the obvious but what’s the procedure to check rollers and maybe cutterhead? Tables maybe?with a straight edge?
I’m adding some photos of the seller. It was his fathers machine, now locked away in a storage.
“[Deleted]”
In a perfect world you'll be able to power it up and run some stock through it. When you do make sure to wear the jointing helmet, you can't be too careful!
Try to find a manual for it and check availability of parts you might need. OEM parts for an 80s machine ay not exist so you want it to be complete.
Find out wht the dad used it for too. If he was a hobbyist and not a pro wear & tear will be lower. All of my pals are planning to be at my estate sale for just that reason.
Yep, what MJ said :)
