I live outside St. Louis, MO. My shop is in the basement with temps no lower than 45 degrees. The titebond glue that I bought is turning chalky. It has not been frozen. Is it bad? Do I need to replace it? I’ve never had this problem with other yellow glue. Thanks.
You probably should be using Titebond 3, it has a much lower working temp (45*). If the TB1 is chalky, I'd toss it.
TB I will withstand cold weather, even freezing. However, you can not use it if the temperature is below 55 degrees (65-70 is best). It will be OK once it is warmed up.
You can still use it when chalky, but the bond will not be as strong as when the temp is consistently above 45. If your shop drops to freezing at night, the glue will become gelatinous and must be discarded.
Thanks for opinions. I thought I had titebond 3,but bottle was used up as was titebond 2 bottle. I go out to store tomorrow and get more of the titebond 3.
According to the maker of Titebond I glue it should not be used below 50 degrees F. A chalking is an indication that the temp. is too cold and the joint probably will have reduced strength. Once back to temperature the glue in the bottle will be ok. If frozen, just thaw and make sure it is above 50 degrees F. before using.
Marion, I too have cold shop. Put a small watt light bulb in the cabinet where you keep your glue and it will always be warm.
