I’m thinking of buying a table saw. They come in left and right tilting arbors. Why would I choose one over the other? Are there advantages to having one over the other.
Thanks.
Thanks.
Check the archives for a lot more on this subject. Table saws are configured so that the fence sits on the right side of the blade, thus your (rip) cuts are made with the stock to the right of the blade. The problem occurs when you aren't cutting with the blade at 90 deg. Say for instance that you're going to rip a 4" board at 45 deg. from a piece of 6" stock. The blade is now tilting toward the fence, and has your 4" board "trapped" under the saw - a rather dangerous situation that can lead to kick back.
On a left tilting saw, you're still working on the right side of the saw, but now the saw is tilting away from the fence and stock, greatly reducing the chances of kick back. The disadvantage to this configuration occurs when you install a dado set. Because the fence's measurement scale is calibrated from the right side of your standard blade, the guide is now off 1/4 - 3/4 inches depending on the width of the dado stack. (Some fences can compensate for the difference, but most can't. I just use a tape measure or rule.)
To me the trade-off is a matter of safety vs. convenience, and I prefer safety. (BTW, my equipment dealer now stocks only left tilting saws. Those who want right tilt models must order them.)
Thanks. That is exactly how I saw it. I'm getting a left tilt saw. Safe is always first with me. Thanks again for the advise.
Lenny Krieg
I must be awfully thick, because I've never understood this problem. Why not just move the fence to the left of the blade and saw there (unless, I guess, you're sawing a bevel on a wide plank)?
