Hi everyone, If you don’t have a copy of this article in front of you the joinery I’m wondering about involves a 16 inch wide sycamore shelf (it doesn’t mention being quartersawn or glued up butcher block style) set inside of four sycamore legs which are two inches square. The legs are double biscut joined to two inch tall sycamore rails. The shelf is joined to the rails with two biscuts per rail. I am wondering what this fixed shelf will do when it tries to expand sideways into the legs. The rails have grain running parallel to the floor so I can’t see them stretching, the shelf is held with eight biscuts to the rails so I can’t see it “bellying” up. Will the shelf bow up slightly taking the rails with it? I guess this much flexing up and down would not be noticable but would it eventually crack the tight joints between legs and rails, shelf and rails? My dad made a kitchen table up recently with a similar situation. I was thinking that the next time I’m involved with something like this I’d make an open mortise into the inside corner of each leg for the shelf to recess into, the shelf could be shaped to move in or out of the slot with enough of a lip on the side perpendicular to expansion to cover up the gap which would be able to form. Is this unnessary? Will enough glue M+T’s or biscut joints freeze the woods movement as if it were a part of a plywood panel? Thanks for reading! Have a Good One, Paul
i "Will enough glue M+T's or biscut joints freeze the woods movement as if it were a part of a plywood panel?"
You raise legitimate questions. I went back and had a look at that article. The author does seem to be asking for trouble, not only in the bottom shelf, but also in the burr elm top. I admit that I would be reluctant to emulate some of his techniques as detailed in that project. The author is normally quite reliable, but I suppose it is possible that he's made an error of judgement.
If you've been reading F&C for a while you will know that Kevin Ley is something of a recent user of biscuits. He's been doing, amongst other things, a little experimenting to test their strength. There has also been some debate in the letters page- same edition, and issue 43, on this joinery technique as described in an earlier project. Interesting observation on your part. You could drop F&C a note asking if the author would be willing to explain to you his joinery selection. The magazines email address is printed in every issue. Sliante.
