Tricks for keeping finishes in an unheat
Thanks for your comments regarding the “Cold Shop” String.
Heare is the issue. I want to store finishes, paints etc. in a shop that will not be heated year round.
It seems like building an insulated shelf area with the addition of some electrical heating devise would work. I have heard a light bulb can keep a small area from freezing. Some Gun cabnets have small heaters to keep out moisture build up. I was thinking of an insulated shelving unit that would be 7’x4’x2′
Any suggestions?
Jim
I long ago had a similar problem with a cabinet about half the size you're talking about. I put a 40 watt bulb inside that I left lit all the time and it did the trick perfectly, but it'll depend on how good the insulation is and your local weather. With some experimenting you'll find the right wattage.
DR
Thanks DR.
Best,
Jim
Any old frig or freezer with a bulb or heat strip will work.
Mine has a thermostat and keeps all my finishes at 60 all year.
Look in your local dump or tranfer station for one the right size and free.
Jeff,
Thanks so much for your advise! I am delighted there is a simple solution!
Best
Jim
Happy to help.
Sometimes the simple answer is right at our feet.
Thanks Jeff,
Did you say a reating wire would do? I have a "heating wire" that is for rapping pipes that tend to freeze -do you think that would be safe to use?
Best,
Jim
I would be cautious about installing a heating wire in an enclosed space. The light bulb trick really does work. You just have to diddle around until you hit on the right wattage."I would never die for my beliefs because I might be wrong."
-- Bertrand Russell
I first used a bulb.
Then switched to one of the heating wires for pipes with a built in thermostat and watertight.
I was careful to drape the wire across the metal rack shelves only, not the plastic.
Worked for 2 years now without a problem.
Keeps the freezer at 60 degrees all winter.
I turn it off in the summer.
